Hi
So I'm still struggling to get my point blank 2 cab stable. It works for ages then occasionally goes to a solid blue screen. With a sharp whack on the side of the cab where the game board is mounted it goes into reset and is ok again. Sounds obviously like a loose connection, dry joint or bad solder point. I'm guessing it is on the board itself as I don't believe a single cable being able to cause a solid blue screen.
I have taken apart all the layers of the board and looked with a magnify glass across everything and can't see anything obvious. I have found that C45, surface mounted cap seems a bit knackered, as the outer sleeve has shrunk right down the side. However, this is next to the volume pot so presume this is related to the audio circuit (which is currently ok).
Does anyone have any pointers? I don't think it is the monitor at fault due to the solid blue and also when cabinet is whacked there are some narrow colour bars that briefly appear before the reset cycle kicks in.
