Point Blank 2 continually resetting
jonwarby
61CR
My point blank 2 has died :(
Last night I noticed it was continually resetting. The screen shows some green to white test bars and then it resets and shows the same test bars. Stripped it all out last night and put it back together and it came back and had been playing fine but tonight its gone again with the same issue. Stripped it all down again but nothing I do seems to make a difference. Have checked all cables, reseated roms, tested voltages and even replaced psu, checked all the board connectors, unplugged both guns in case they were causing an issue but always the same reset loop.
I don't have any other system 11 boards to try and isolate the fault.
Does any one have a PCB cage for sale? or suggestions as to where I can start to look or send for repairs?
thanks in advance for any suggestions
5,653CR
I have a PB1 set in cage with gun IO spare. But not a PB2 unfortunately.
If you want the PB1 set until you can find a PB2 PCB send me a PM.
bonehead
I'll get pix tonight
50 (100%)
1,729CR
My pb2 did exactly the same.
Checked voltages and all were fine.
Played it a week later and all had been fine since.
Hope you find another pcb as it is a cool game.
Steve
bonehead
50 (100%)
1,729CR
I did change the power supply but set to the same voltage of 5.1v
Maybe the power supply could be slightly faulty and flaky.
I guess you could try changing it if you have a spare.
It might be worth trying!!
Steve
jonwarby
61CR
Thanks for the suggestion. Already tried that :( tried voltages ranging from 5 to 5.2 and tried a new psu tonight but with the same results.
jonwarby
61CR
Been in the garage today putting up some plasterboard under the rafters to try and make it easier to heat as it starts to get cooler and whilst resting my arms had another look. I can get it to boot now by holding down the credit / service button whilst its reset looping and it will then sit on the instructions screen for ages. As soon as you hit a player button and you get to the menu screens where you choose your level it will let you select the level and then display the four game choices but every time you shoot a game or let it time out the machine will crash and go back to the reset loop.
jonwarby2014-09-01 16:38:32
jonwarby
61CR
Purchased a Point Blank PCB with filterboard and cage from ebay and fitted it today and works a treat. Enjoying playing it and the game doesn't look too different from PB2 at all despite the older hardware. Will still keep an eye out for a PB2 PCB as would be nice to be able to play both games in there.
The PB1 filter board has an extra connector on it. Out of interest does anyone know what its for?
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
I did some reading about just out of curiosity and found this info
these connectors were used to plug strobe lights in for when you shoot, we never used this in the UK market, probably something to do with epilepsy (From Namco Tech Support)
5,653CR
Wow that's cool to know!
In regards to the resetting issue. It's probably the mainboard and not the Romford. I think PB2 uses the Sony PS1 hardware. Verify that's correct (system16.com) and then find another motherboard from a Tekken 1 or 2.
jonwarby
61CR
Yea I think its System 11 which is based on the playstation.
There are four boards in the sandwich there is a bottom layer which is the mainboard then next layer up as a small rom board and the gun board and then above that is the CPU board.
I think the game roms are surface mounted on the main board making it unique and the graphics roms are on the small rom board and I assume that the CPU board is the generic bit that could potentially be swapped?
