Point Blank 2
IDCHAPPY
KANFU Master
9 (100%)
1,523CR
Ok, i have the PCB and the filter board:
http://www.ebay.co.uk/itm/170720396085?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
And a set of guns:
http://www.ebay.co.uk/itm/260882527063?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Now i need to get them working together hopefully
trm
2,877CR
Nice one. You shouldn't have too much trouble as the PB manuals have a pretty useful wiring diagrams.
There are quite a few of us PB owners on here so if you have any problems shout out. The guns may be the hardest part as you'll need to make a converter for them to interface to PB but there shouldn't be any black magic required.
Keep us updated!
G
Guests
Guest
think the guns will need modifying as there not proper Namco guns
IDCHAPPY
KANFU Master
9 (100%)
1,523CR
What extactly does the filter board do? does it take the inputs from the Namco guns and stuff?
I'm gathering the additional connector on the pcb thats beside the jamma one deals with gun inputs?
Thanks for the help guys
trm
2,877CR
Yeah, they will be the trickiest bit I reckon as you'll have to provide some power for the recoil too (normally 24V in a PB cab iirc) which you won't get from a standard power brick. But the ad says the full instructions are supplied so best case it'll be making a wiring adaptor from the dox and worst case perhaps wiring an inverter to the gun sense output (although I suspect the guns will be wired the same).
All very doable though so don't be discouraged :D
trm
2,877CR
The filter board is a US requirement to suppress any stray EMI from the game and isn't required for the game to work - assuming you remake the connections to distribute power and signals.
The gun sense board is part of the main stack and from memory is where the cables disappearing into the board stack terminate. The filter board has some Amp connectors for the cab loom which route the guns to the blue connectors on the back of the filter board.
The gun works by having a photosensor behind a focussing lens. When you pull the trigger the photosensor is enabled and the screen is simultaneously drawn in white. As the raster beam of the monitor draws the screen (left to right, then down a line and repeat) the photosensor picks up a spike when the lens is aligned with the X & Y position of the raster. The board detects this spike from the photosensor and as the game knows the X & Y raster position at all times, it also knows exactly where the gun is pointing and whether you just hit something.
The white screen is needed to give a maxed-out reading on the photosensor which is why light gun games of this age all have to flash the screen. You (the game HW designer) can work around this to avoid the white flash but on older hardware it's not easy to do as the afterglow of the CRT phosphor combined with dark backgrounds make it hard to figure out when the gun photosensor is spiking due to looking at the current X/Y draw position.
Got to love what the Amiga Hardware Reference manuals taught
trm
2,877CR
Good luck ;) That ionpool doc seems to make this harder than it looks! If you have trouble post a pinout of the gun connectors you have and we can either figure it from the PB manual wiring diagram or beep test it out.
Just be careful when jumpering 5V or GND to anything: if you're not certain post as I've seen most PB filter boards with vaporised tracks due to power shorting - I suspect when Ops tried to bodge different guns in :(
