Nice fix. Have to look for the most simple of things before you start getting into too much troubleshooting. Power and connections are often the issue.
Without a return path for your current, in your case the 0v, you will always get a lower than expected reading as the voltage will not be able to flow so the meter will read it as a low voltage.
As a ref point for checking voltages, always test between live and neutral and live and earth. This will give you an indication as to wether your neutral or your earth path is incomplete.SUPERSPRINT2019-10-29 18:50:09
