Point Blank sensor board for PB2?
G-man
181CR
On a Point Blank board I have, there is an additional 'gun sensor board' plugged into the side of it.
Does PB2 require this board also? The one I have (PB2) is a much smaller boardset but with similar cables.
G-man
trm
2,877CR
The only board I recall having to hack about with when I converted my cab from PB1 to PB2 is the front filter board as I my PB1 boardset had one but not my PB2.
I think I can get easy access to my known-working PB2 so I'll go have a look, unscrew the case and get you some pics.
cheers
tim
G-man
181CR
Ah ok, sounds good then.
The PB2 I bought has a filter board with it, it was just when I saw the extra gun sensor board on the pb1 that I wondered whether PB2 needed one.
G
Guests
Guest
oll is correct pb2 boardsets have the sense built into the main pcb
trm
2,877CR
For pictorial reference, here is a known working PB2 cage/boardset.
There is a bit of extraneous wiring on the PB2 board to filter as I didn't get the complete boardset as expected so I had to hack up a lead to convert the IO.
cheers
tim
trm
2,877CR
Oh yeah, I got skanked on the cage too.
I posted about it at the time but there is that amusement business down south that cleared out a lot of stuff including tonnes of SWTs and plenty of fruities. They put it up with a 99p bid and nobody went for it bar me. They then pulled the auction a day before it was due to end. They relisted the week after and the exact same thing happened, so I mailed them and asked WTF. They said they weren't prepared to sell for such a low price so in the end (I really wanted PB2) I think I offered them £40 for it which they took. And then it turned up wrapped in a sheet of newspaper and no wiring, cage, cables or filter boards so I had to work out the differences between the PB1 & 2 wiring and then bodge that cable you can see coming from the board and into the right hand top corner. It's just cables twisted into a mate n lok so I could revert back to PB1 :(
G-man
181CR
The PB2 I have has the golden coloured front plate into an old PB1 silver cage. I think all the wiring is there, but until I can find a decent PB machine, I probably won't know for sure.
Thanks for all the info however, much appreciated.
G-man
trm
2,877CR
If you want me to disconnect some of the boards out of the stack for a clearer picture just LMK. It's no problem.
And should you find some minty guns on your travels I'll buy any that you don't
G
Guests
Guest
i have a complete factory pb2 set next to me if you need any pics
G-man
181CR
Cheers for the offers, but it looks like the board I have is what everyone else has, so thats good news.
If anyone hears of a half decent PB machine going for sale, keep me in mind. (I missed the one that sold on ebay last year for £7!).
G-man
