Point Blank
maskeddev
88CR
Hi Guys,
Some of you know that I got a Point Blank cab and it needs some serious love and attention. Basicalyl, I got this cab on ebay, good deal, mostly working.... and it fell in half outside my house. Had a "fun" couple of days getting it back together again. Anyways...
There's a fair bit to this so I'll go one step at a time!
1. CP has no screws, nuts, or bolts, or anything. It's just sitting there. What bits do I need to fix this to the cab properly?
2. Marquee has no bolts, and only one of the three threads in place. What's the spec of the bolt I need?
After getting these bits in place I'll then ask you about the monitor, the monitor's wooden frame, and the light gun sensor. If you have a spare wooden frame or working gun, I'd like it please. :)
Thanks,
Aaron.
G
Guests
Guest
I've got a ton of screws coming from a dismantled Rave Racer twin cab. Might use the same screws as your cab as it's Namco...? If they are of use to you I'll be happy to send them to you for the cost of post.
maskeddev
88CR
Maybe mate, and many thanks for the offer! I know some guys around here have Point Blank cabs they can check these things with so hopefully someone will come back to us :)
maskeddev
88CR
If someone can let me know the dimension of the wooden frame for the monitor, that would be great too.
The one I've got does not line up with my metal sides, holes, and is bowing in the middle a little so expect its not the original and is not thick enough?
Someone must be able to open up their own Point Blank and check for us please?
After knowing about these fixings, I only have two other bits to sort :)
Rotunda - might take you up on your offer mate. If nobody comes up with any specs for the screws, I'll be sticking about anything in there! Will give it a bit of time first
G
Guests
Guest
No problem mate it's all arriving mid week this week so plenty of time. they aren't going anywhere.
maskeddev
88CR
Still needing some spec for some basic missing parts and the monitor frame. There are two other thins I need to sort as well.
The monitor has a bit of a wobble during the menu screens. I'll get back to that.
One of the guns is not working, presumably a faulty sensor. Where could I potentially source another one (sensor or gun)?
