Pole Position. Not enough throttle...
smarty
Ready Player One
1,303CR
Hi All,
Testing a new 5KOhm pot. in my pedal assembly. (the on Raven mentioned here) Test mode shows that there is not enough travel in the pedal as it only reaches x72 when it should go around x90 - xA0. I think the cable is wired correct so what could be wrong? The old pot worked fine. There is just less than 180deg of travel in the pot from the throttle being fully released to flat to the floor.
Video below showing the pedal movement best I could get it.
If anyone has a pedal they could check against that would be great.
Cheers, Mart.
trm
2,877CR
You say you can get 180 degrees of rotation when using the pedal. How much rotation can you get if you operate the pot by hand? I don't know how the ADC works on PP but it sounds like the pot isn't sweeping over its full range.
smarty
Ready Player One
1,303CR
Its slightly less than 180 degrees with the pedal, without the cable the attached if you turn the pot manually you can get to the desired levels, which is a turn just over 180 degrees. The pot is neverending, rotating from 0 Ohm to 5K, then back to 0.
The pot measures 5K exactly across the pins end to end, and either end to the wiper moves nicely from 0-5k (in a full revolution I think)
Wherever you start the pot position from when you reset the game, the pots current position get calibrated to x00 which is the pedal in open mode.
I may just get another pot, to try as I was fine with the original one before it broke to pieces.
