police 24/7
JohnBud
429CR
hi guys, i have a police 24/7 that i hoped was a 5v problem, sadly its not.
im getting nothing on the screen, i have traced the av line and it is giving me 118v ac
the neck is not glowing. i managed to slide out the monitor, so that i can get to the chassis. i will post a picture of it and take it from there. i can juggle monitors about but these things are 29" crts and weigh a ton. i can see a fuse on the chassis i will test this out. im hoping its just a fuse as the monitor cant be very old.
i will report back soon. cheers.
john bud
trm
2,877CR
Hi JB,
First of all, you say "i have traced the av line and it is giving me 118v ac" do you mean you've traced the AC line and found it reads 118V? I'm pretty sure you don't mean you've found 118VAC down the video line but it pays to check.
Can you explain how you definitely know it's not a 5V problem (I again assume you're talking about the feed to the logic board)?
If we can go all the way back to the beginning of your checks it'll help us build a mental image of what you've got there. It does sound like a monitor fault if you've got power to the monitor but no glow. Do you get the static crackle on the screen when you power it up? A good way of checking is to turn it on and then run your hand over the screen. You should feel a static charge if it's got HT.
Report back on how you eliminated the 5V problem and whether you get any static and we can take it from there. Have you found a manual with wiring diagram yet? If so a link would be cool.
cheers
tim
EDIT: Can you also tell us what monitor model is in there?trmatthe2010-08-23 16:08:30
JohnBud
429CR
i have checked the 5v dc at the jamma connector, it was 3.9v. i have adjusted it up to 5.005v.
i hit a switch inside the coin area and it sounded like it was a degauss. the pictures
AnDyC2010-08-23 16:50:50
JohnBud
429CR
how come i can only post 1 picture at a time ???
im getting 118v on the ac feed to the monitor. i can hear very well so crackle i dont know. i tried to find a guide but couldnt. i have also removed and re-inserted the memory card. but still no joy. all the lights at the edge connector are red. they also give out a sequence of lights that i suspect may be a fault code. but without a book im gubbed. im sure at some point i had at least i green led lit, but that was a few months ago. i have a keen sense of smell (a very handy diagnostic tool) but i cant smell anything burnt out. i also found 2 fuses and checked these both were ok. i hope this helps. thanks in advance.
john bud
trm
2,877CR
If you can't hear so well then don't try to listen for start-up crackle - you should be able to feel it. When the monitor is supposedly powered up rub your hand over the screen. If it's got HT then it should feel like static electricity is covering the glass.
JohnBud
429CR
i will give it a try but i need a help putting it back in its hole. the cable is too short to reach the monitor. i think 1 of the monitors in my naomis may be the same. but its a pain to take them out. i think i should have eaten my porridge when i was younger. these monitors weigh a ton. cheers.
john bud
trm
2,877CR
Hehe. Some of them are quite heavy aren't they. The number of times I've rotated my Naomi monitor on my own means a) I have no sensation in my fingers from crushing them and, b) I have muscles like Popeye!
To avoid any unnecessary complications I'd definitely advise not making any changes to the cab whilst we're trying to troubleshoot it - it makes it impossible to build a mental picture of what has been checked out and what hasn't if things are being shuffled.
Troubleshooting is all about a logical approach of testing and changing one variable at a time, so stick with us :)
Getting the screen back in and checking for static feeling on the screen is #1. You could try holding a sheet of A4 just in front of the screen (an inch or so away) and it should get sucked in if the monitor is producing HT (aka High-Tension aka High Voltage).
cheers
tim
DanP
Administrator
2,232CR
Hi John, back to basics, does the game play blind at all (i.e can you hear any sounds when you coin, press start, etc)? Is Police 24/7 a Jamma board (or Jamma +)? It looks like it is, if so are you able to test it in another Jamma cab or test rig to eliminate it as the problem. We really need to nail if it's the game board or monitor that has the problem (or both).
Dan
JohnBud
429CR
reet im back. i moved the monitor back a bit so its resting on the cab. i have now connected the monitor and its fired up. im getting a grey/blue screen with lots of scan lines. but still no picture or sounds. the psu seems to be fluctuating. im starting to think the monitor has been adjusted, not by me. also when i hit the demag button it doesnt make any noise. the monitor also has a white line at the right hand side. the line goes from top to bottom.
could i take the board out and plug it into another cab ??? i have a virtua fighter cab i could try it in. i know the virtua cab runs at 15khz i think its a nanoa monitor. the board has 2 jamma connectors, im assuming the other connector is to do with the gun or possibly sensors. cheers.
john bud
JohnBud
429CR
but can i plug the board into the virtua fighter. even if it is all over the place ??? there are 2 jamma connectors im assuming the second is for the gun or sensors. will the board fire up albeit i cant play it. if i can at least prove part of the circuit it would be a bonus. any idea what type of monitor is in the 24/7 cab. cheers .
john bud
JohnBud
429CR
found some stuff on vaps, its about nvram and batteries with a security dongle if you upgrade to 911/2. it would appear 911/2 is aka police 24/7. i may have missed the point though, some guy says it has a battery, with a life expectancy of 8 years. it also adds if the battery fails so does the nvram, thats when the security kicks in. it looks like.
battery dies followed by nvram failure. and a hard job to get it booting again. but thats maybe just the way i read it.
i still think the red flashing leds are a fault code. if i could find the manual for it im sure the code would be in it. i will continue the search but im not to good at searching. all i seem to find is dirty women
i only recently discovered that sometimes smutty things get saved in your download folder. anyway i shall continue the search. cheers.
john bud
JohnBud
429CR
im bored, i have decided to plug the gameboard into the virtua fighter. 2 reasons
1 they are both medium res monitors
2 if its jamma it aint gonna do any damage trying it. they both have volts at the same place.
see ya soon.
JohnBud
429CR
its looking like a gameboard fault. when i pluuged the 24 into the vitua cab zilch. when i plug the virtua game into the 24/7 cab it displays a picture of sorts. the screen needs tuned in, but i will not play with anything. there is no way on earth im attempting to fix the board.
so the choice is this.
strip the cab of parts nice monitor
or pay for a repair. i have a spare monitor.i have used phil before and i know he has just joined. but im interested to know, is it an output fault on the pcb. or the dead battery which has taken out the nvram ??? i dont want to spend a lot on it cause im skint but i dont want to kill it. my heads telling me it could be quite pricey to send away for a repair. but thats down to what i have read. with this cab, price is a factor, i have a gun set up on a naomi but this looks pretty cool. this was another cab aquired for the monitor. it took 4 of us to lift it. but it will burn in about 4 hours
so best advice please on costs to repair and wether its worth spending on. i should also add that i would like to get it repaired. but i have another big cab coming soon. so i really dont want this in pieces. cheers.
john bud
JohnBud
429CR
im of to work but when i get back i will have a look at the pcb. i wont touch anything but i will take it out the cage and see if its anything obvious. can anyone advise me on the nvram thing ??? and the battery. if i can find it i will check for leakages. and can anyone advise me on a possible cost to fix the board or who would do it. i think phil has taken an extended holiday away from repairs. at least i can build it back up, thats a plus anyway. oh and lastly does anybody know if the monitor is tri or dual sinc. i think the monitor is running at 31khz just now, hence the dodgy picture but again i could be wrong. but i need to shoot just now so i will be back later. cheers so far guys.
john bud
JohnBud
429CR
the story so far. as much as possible the game has been tested and is gubbed. i tried keeping the test button in whilst switching the cab on. this was an attempt to reboot the nvram. it didnt work
so i managed to find someone who will attempt the repair
davie nipped over and we put the monitor back in, and i will post the gameboard tomorrow. on saturday i have a crazy taxi working, and a starblade arriving
the starblade plays blind and has a replacement monitor. the problem is what wires go where ??? is there an auto hit things setting on starblade, i told the mrs about the vibrating seat and she is quite looking forward to it
anyhow i will report back with the 24/7 saga. cheers.
john bud
