Polo 20 brightness issues
mappy24
43CR
Hi all,
I've got an ongoing saga with a Hantarex Polo 20" monitor, the main issue is that after being powered on for about 15-20 minutes there is a sudden noticeable brightness drop and everything becomes washed out.
Today, I switched the cab on and there was crazy interference on the screen plus an electrical sparking noise coming from the monitor, here's a video https://youtu.be/_SM3kHHZ00g
I discharged the monitor and removed the neck board to find this suspect wire:
I've shoved the wire firmly back in place and the monitor is working well again, no sparking, with the added bonus that the brightness issue hasn't happened in over 30 minutes (but I'll give it a longer test later to make sure).
Question is, what would be the longer term fix for this? Does the component in the above picture come to bits so the wire can be secured in place properly? Does a new flyback come with this bit attached?
andyman
1,059CR
The plastic part where the wire enters usually unclips and red wire is soldered to a post...new flyback comes with the bare ended wire only
Edit : Polo...pull and twist wire or in your case push and twist, its a pushfit connector so you may have sorted it already ;)
andyman2020-02-02 19:28:07
gunblade
9,144CR
https://www.ebay.co.uk/itm/TV-Television-Part-White-Plastic-Shell-9-Pin-CRT-Socket-GZS10-2-108/133218190961?hash=item1f046c4671:g:Zn0AAOSwPqZeHVZg
the pins are further apart on this socket but you will see the neck card has through holes in the correct place
mappy24
43CR
There are only 9 pins on this, but I count 11 pins on mine?
mappy24
43CR
Thanks, I've been searching for crt sockets on Google with little success. The best I could find is this but will go with whatever you recommend!
tb2000
3,584CR
I'm 99.9% sure that socket gunblade recommended will be fine. The 2 pins closest to the focus pin are either not connected or are grounded from what I remember.
mappy24
43CR
gunblade said:
my cards all have 8 pins actually soldered
do you have a photo of the solder side of your card
Here's some close up pictures of the whole thing.
https://imgur.com/a/Kby5nXK
I had the cab on for about 15 minutes and it started making the sparking noise again with interference on the screen, checked the wire on the CRT socket and it's in nice and firm, is the socket just knackered?
mappy24
43CR
OK, I went for the CRT connector that gunblade recommended and it arrived this morning. I fitted the new socket tonight but when I put everything back together and turned it on I instantly noticed that there was unusually bright neck glow accompanied by a loud whining noise, the interference was still present and the screen had a nice shade of red to it, so it was now worse than before!
I removed the chassis again and checked my work, which all looked absolutely fine, so, in desperation I decided to put the old CRT socket back in again and guess what - it's now working 100%
It's been on for almost an hour, no problems at all. I'm happy it's working but not knowing why is frustrating!
mappy24
43CR
I'm not sure what you mean? The socket fitted perfectly in the larger holes on the neck card, just like you said it would, it was in the correct, matching numbered holes (4 to 4, 5 to 5 etc. it would only fit in one way) and I soldered all the pins? Did I do something really stupid?
justez
38CR
gunblade said:
you probably pinned like to like which is not correct
I
had the same problem at a hantarex polo 25 using a similar socket by soldering
the pins of the socket which indicates the pcb 4-> 4, 5-> 5
Should I solder the socket in some other way?
Is there another pin match?
justez2020-02-27 18:13:12
mappy24
43CR
justez said:
I
Sounds like you did the same thing as me. The socket would appear to only fit in one way, so maybe you are not supposed to connect one of the pins, I have no idea....
