Afternoon! Can I get some advice on my Polo please - it's running on a 28" screen. When it's powered on all I get is ticking so I'm assuming that's the PSU starting and then shutting down immediately.
Using bits of info from other threads dotted around so far I've:
Any pointers on what to check next would be appreciated.
Cheers, Steve.
- put a bulb across pin 3 (desoldered) and pin 5 - when I do this the bulb lights up. The test points show TP6 145v, TP8 26v, TP9 17v and TP10 12v. To me that all looks OK
- removed the HOT and tested it out of circuit - it's fine
- with the HOT still removed run a bulb to pins 1 and 5 of the LOPT - bulb lights up
- again with the HOT removed run a bulb over the C&E pads - bulb lights up
Cheers, Steve.
