Polo 3 issues
Chopper79
668CR
Just bought a polo 3, and running a 19" orion A48 mini neck tube. I bought as tested but several issues.
Grainy image. I did a partial cap kit, and slight improvement, but still visible. If it wasn't for the grainy image, it would be a nice picture.
After around 5 minutes, image shifts either to the left or right about an inch at random, and adjusting the horizontal frequency brings it back, but 5 minutes later happens again. I tried a NOS remote board, but same issue.
Screen shakes slightly from left to right. Tried another PTC, and still happening. Also disconnected degauss plug, and still the same.
Already spend 3 days on this chassis, and not getting anywhere. Hopefully one of the monitor guru's can help shed some light on issue.
neoretro
1,121CR
Grants help will be much more useful but out of interest are you testing this in a cab?
I’ve had issues where the power cable to the monitor was running close to the pot, in some case touching it, and it caused issues with the horizontal and vertical positions
Chopper79
668CR
Also forgot. When I first got chassis, it took about 15 seconds to display a picture. The heater resistor on neck board was a 8R2, and the seller said to change to a 4R7.
Chopper79
668CR
Seller sent me a replacement chassis, made by elvid. Looks like a hanty clone. Told me he tested for 2 hours. Put in my cab, and just a black screen! Got neck glo, but no picture. Put polo 3 back in, and get a picture. Grant you may have 2 chassis coming your way, as I'm ready to go bruce lee on them!
tb2000
3,584CR
Something a bit odd going on here to say the least!
Edit: I assume you know for definite that the pcb you're using for test is working 100%?
tb20002020-04-29 16:27:02
Chopper79
668CR
Game pcb 100%. It's in cab now. I tested pcb originally through a gonbes into a lcd, and picture perfect. Maybe I should just fit an lcd!
tb2000
3,584CR
What?
