Polo2
Sluggy
73CR
And in other news and the reason I'm looking for a chassis....
This chassis came with sega rally it was dead the man said...
Checking the chassis I have the tick
So went through the steps
Replaced hot and it blew
Replaced the t6 and T1 and R151 as it was burnt and the hot again
Powered on and adjusted the b+ to 138v
But now I get a nice power hum but no static on HV and no neck
Replaced R35 as it was a bit off but still no start.....
Any thoughts
gunblade
9,147CR
yes pretty common issue, you should check the b+ before installing new lopt- polo 2 auto should be around 110v and polo 2 15k should be around 140v
gunblade
9,147CR
i set my polo 2 auto to 108-110
if its a polo 25khz then b+ could be anything from 130v to 145v depending on model- whats the exact model number of your chassis
gunblade
9,147CR
like i said 108-110 b+, if you are not getting that them you have an issue in the power supply section- have you replaced the 2 x 22uf 63v and the 220uf 25v in the psu section yet?
Sluggy
73CR
here's my rundown of test points.....
SP36 209V Should be 171v
SP37 209V Should be 130v
SP4 149V Should be 105v
SP5 20V Should be 25v
SP8 13V Should be 16v
TH1 TEST
JP1 149V Should be 152v
JP9 149V Should be 105v
Im feeling it but cant put my finger on it!!! HELP!
Sluggy
73CR
Am I barking up the wrong sausage here.... Does the power change before the TH1? I'm beginning to wonder if the autoswitch changes before it's input to that transformer? In which case I should be looking at the switch board??
