Portable Pac-Man Project
cowboystyle
2CR
Hello!
I've been fascinated with Pac-Man since I was a kid and have finally decided that the versions I've collected on C64/Spectrum/Beeb & Atari 2600 aren't quite the same - I need to get THE Arcade version, on original hardware.
Sadly I don't have space for a Cabinet at the moment (or the money!) - so until I do I plan on getting the PCB and mounting it in Perspex as a working, portable display piece. I was hoping someone here might be able to tell me whether this would work fine (particularly when it comes to display!) or highlight any issues? Any help at all would be greatly appreciated!
I'm going to mount the PCB like the Bubble Bobble image attached I found online with PCB standoffs, and have the Midway Pac-Man logo on the front - possibly backlit with Mini Edison E10 bulbs.
For power, I plan on using a 12VDC Switching Adapter (5A?), and building a mini regulated 5VDC circuit from the +12V using a simple 7805 Regulator w/capacitors circuit. Sound I'll run to an 8Ohm speaker mounted at the front and the Up/Down/Left/Right/Start controls I'll wire to a DB9 connector so I can plug in any standard Atari style joystick and use FIRE to start.
Video I have a few questions about - I've read posts online about people hooking up to TVs with no problem, and I've seen lots of pinouts for JAMMA to SCART (with Audio), and JAMMA to VGA. But I've also read posts of people having complete nightmares with TVs and Syncs etc. Generally speaking - If I wire the R/G/B/GND/Sync/Audio pinouts to the right pins of a SCART socket, or the right pins for a VGA socket from the PCB, am I likely to get a display on CRT TV's or LCD Monitors? I have a couple of CRT/LCD's here but don't want to fail at the most important hurdle!
That said, my BBC Micro and BBC Masters also send video as RGB with +5v and Combined Sync for my old CUB Monitors, and I've had no problems with converting that output to SCART.
Any thoughts/opinions would be greatly appreciated!
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
one thing i can tell you for sure is the 5A on the 12V lines wont be enough once regulated down to 5V
your 5V line needs to be at least 7 or more amps (well known issue) even after DC modding the PCB
remember that pac-man is a AC Voltage PCB originally
also trying to regulate more than 1amp on a 7805 will give you major heat issues
porchy
994CR
Just did a quick check with a psu to see what my pacman pulls
As you can see the +5v pulls over the 1.5A that a 7805 can supply.
My board has both the customs replaced with ColinD's CPLD replacements AND also using one of Phils single EPROM adapters too so definately saved a little on using those too.
obcd
3,830CR
C64, Beeb, atari 2600 and Speccy didn't have the cpu and graphics power for a decent pacman game. The moment they made the pacman clones for those, they probably didn't knew how the real arcade pacman ghosts managed to keep being on your tail. So, it's normal that the gameplay wasn't the same as the real thing. Nowadays however we have mame that emulates the old hardware and uses the original game software. If you are only looking for an accurate original gameplay experience, a raspberry pi and a proper mame for it might be the cheapest way to achieve your goal. If you go for the challenge of making the real old hardware working again, forget about this post.
cowboystyle
2CR
That's lower on the 12v than I expected! I do have a box full of these... http://www.ebay.com/itm/5X-LM2596s-DC-DC-Buck-Converter-Power-Supply-Step-Down-Module-Voltage-Regulator-/301886482972?hash=item4649d62a1c:g:8cwAAOSwUuFW1lhy somewhere that might be of use... they're adjustable too so I can get around the voltage drop.
They're rated up to 3A so would satisfy running as yours is quite nicely - It's the 7A requirement that Silverfox has mentioned that I'm concerned about - and the difference between using a tiny step down converter and buying a ££ ATX/ITX PSU!
cowboystyle2016-05-23 21:17:20
Battlezone
410CR
I echo the concerns about using a small DC adapter,
you'll need more amps, you might want to get an
arcade switch mode power supply to power the board.
SCART will work. Some TVs have a blanking pin
that will need to be tied high or low in addition
to the usual RGB/GND/SYNC. Pacman is a vertical
monitor so you'll need a TV you can flip on it's side.
For a truly portable solution the Raspberry PI
is worth considering. Search for Cupcade. I built
one and it works fine, I'm not saying it's as
satisfying as a cabinet, but it's running the real
code. Here is a picture of my disembodied setup running
Pacman, I badly need to find time to print an enclosure
for it.
cowboystyle
2CR
Thanks John - I've got a couple of Pi's here I've used retroarch on before (but not Mame) - It doesn't feel satisfying to me though. There's something awesome about using the original hardware (although it'd be a shame not to have an original cabinet). Today's dilemma is whether to go for a Pac-Man or Ms. Pac-Man PCB but I've found the daughter boards on eBay for £15 so very well may be cheaper to buy a standard Pac and upgrade!
Battlezone
410CR
The original hardware is always best. Even when you can't tell
the difference between that and a good emulation, just knowing
it's the original hardware is good in its own right.
> Pac-Man or Ms. Pac-Man.
Obviously it's personal taste, but for me it's Pac-man all the way.
cowboystyle
2CR
Is the 5V line likely to go over 4.5A? I looked at the PicoPSU's and the wattage seems like overkill (and £££!) especially if the 12v line uses <0.1A. :(
with a 12V 5A Adapter, and a DC-DC Buck Step-Down module, I can get a +5V 4.5 output, whilst leaving 2.1A for the +12V Line + any lights!
