Pot to control volume?
tonyg64
22CR
On my recently bought Jamma cab, one of the boards I have Space invaders DX (by Taito) has no volume control and its too loud for the house. Can I simply put a pot in the + wire to each speaker to lower the voltage to the speaker? Im concerned about the board being unhappy if theres feedback due to the restance downstream. If I can do this what type and rating should I go for?
Thanks in advance
Tony
big10p
Coins detected in pocket!
6,088CR
There's usually a volume control pot somewhere on the PCB. It'll probably be quite small so sometimes hard to spot - usually near the sound amp circuit. Someone more familiar with SI hardware will probably be able to tell you exactly where it is.
jonhughes
1,156CR
There's a little white button on the corner of the PCB. Press the button with the PCB on and it will take you to the test menu. The volume is adjusted there.
If that doesn't work you have another issue.
tonyg64
22CR
Jon, that worked a treat
thanks or that. Another little thing, not sure if its game or cab related, When I select 2 player the screen comes up and game is playing but the shooter doesnt move or fire so you just get bombed quickly. Is that a jamma wiring thing maybe?
Tony
tonyg64
22CR
That sounded wrong reading it back. When I select 2 player, player 1 works as normal then when its player 2 time the game plays ie bombs dropping on you but theres no control for you to move or fire.
Tony
big10p
6,088CR
Just looked at this in MAME. Sounds like you have it set to U/R Double instead of U/R Single, in the Configuration sub menu (assuming your cab has 1 joystick).
big10p2016-12-01 20:13:30
