Power supply 5v issue
mozie
20 (100%)
530CR
Having an issue with a new power supply someone may be able to avise, out of the box I was getting 5.25v so adjusted back down to 5v before hooking up a board. Board worked fine but no audio, presumed since my test board is a boot it might need a bit more juice so adjusted back to 5.25v and sure enough audio came back. Tried a few other boards and 5v and same thing, some have no or distorted audio, back to 5.25v sounds are fine.
Also tried a cps2 board which run fine at 5v on my other cabs and the game has no audio and won't coin up at 5v but works fine again at 5.25v.. I'd rather not leave the power supply at the top end of the level. Anyone have similar experiences? Don't have another switching power supply on hand to swap over at the minute but have one on order.
Shinydaz
814CR
My jamma cab power supply is set at +5.2v all the time, it will drop once your pcb is hooked up. What is the reading when your board is hooked up? What's the +12v reading?
mozie
20 (100%)
530CR
Thanks for the prompt responses guys, I'll have a check of the 12v and see what's it's at. I know voltage will drop but most my other cabs are at 5.08v and have no issues unless there's a boot in there. I measured at the jamma connectormozie2018-04-04 12:46:54
