Hiya,
I’m trying to replace a faulty power supply but having trouble sourcing a direct match. It’s a Min Dong MD-9916A-24V, however the 24v output is not connected so I’m sure something else would suffice. Can anyone recommend a suitable replacement please?
Andy
Ok Thanks, I’ve had a look round and found similar models but the 12v are only rated at 4A where as the failed one is rated at 12V 6A. It’s for a coffee table style machine would you think 12V 4A would suffice?
What board are you powering? The 12V wiring to your PSU looks thicker than the 5V wiring so it’s possible whatever you are running needs the extra amps on 12v compared to a standard arcade pcb.
That Min Dong PSU appears to be around 110W of power. I think the Meanwell RD125A might be suitable replacement which has 7.7A on both the 12v and 5v. Have a look on RS here:-
