Power supply voltages help
Moonchild
1CR
I have just acquired an original Solar Warrior jamma board from 1987, with the intention of building a cabinet. My question is regarding how critical the voltages are. This board requires -5v. Using a voltmeter I can adjust +5v to approximately 5.05v, but this leaves 12v at approx 11.80v and -5v at approx -4.45v.
Could anyone advise if these voltages would be satisfactory? I have an adjustable PSU, so this can be altered but obviously all three will change. Just need to be reassured that I'm not going to damage the board before I test it.
As you've probably already worked out, I'm a complete newbie to this, so please bear with me!
Many thanks in advance
Mark.
5,332CR
The 5V is the critical one as all the logic devices run off that.
The others are for audio amps and ancillary stuff like coil drivers (-5V is often not used).
So the levels you describe should be fine.
Just check the 5V again when the game is actually running and pulling a bit of current.
Moonchild
1CR
Hi John,
Perfect answer.  I'd kinda ascertained that +5v was critical, but now I know what they all do, and what to look for.?
Thanks for your help,
Mark.
bones
1,628CR
Hi Mark, regarding the +5volt, I was always told never to have it set above 5.26volts at any of the TTLs on the PCB. I turn it down, power up the PCB, take an on board reading at edge connector and raise it up to just over 5volt and then check the TTLs are all getting at least 4.9volt.
