Power supply
Shinydaz
814CR
So I'm checking over my recent cab and the game keeps resetting. As I'm learning, power is the first thing to check. Upon removing the back door, a burning smell hits me. I follow my nose to the power supply. After a quick strip down, its clearly ready for the bin.
simonden
20 (100%)
1,042CR
Agree as above, replace burnt out component and maybe do a cap kit. These old PSUs have lasted 20-30 years and with new caps and dead components replaced could do that again. Newer PSUs may be cheap but they use cheap components and don't last that long.
Shinydaz
814CR
Yep it was intermittently working. The caps I can replace, the component that has failed I'm guessing is a transistor? Are schematics available? It's a Pal co Ltd power supply. Cheer for the advice.
RSwanson
205CR
Looks like a switching power supply. What has burnt, it will determine if it's worth replacing.
Linear PSUs will last 20-30 years (* in most cases) (and are easy to fix), unlike SMPS ones, which is why it drives me crazy when people replace good old reliable technology with new cheap crap that will die much sooner.
Ace`
PlanB contributor #1
40 (100%)
4,038CR
The problem is linear power supplies usually take out the board too when they die. The one in my space invaders cocktail was putting 8v out on the 5v line. I did repair it in that case but for most games I'd rather have a switcher that's cheap to replace and has short protect / won't kill the board.
RSwanson
205CR
The switcher in my goliath cab (the good old hantarex US250) died, shorted and sent 240 to my r-type board, as well as making my monitor catch on fire.
My track and field cab also tried to burn my house down due to the switcher.
From my experience, linear psus inherently die more gracefully than SMPS. Take Atari AR1/2/3, amazingly designed PSUs, that will easily out perform todays SMPS (obviously not efficiency though).
That space invaders psu must have been 30 years old, a good quality SMPS in a PC will only last about 8 years, what would it be like after 30?
