Powering down arcade machines
big10p
Coins detected in pocket!
6,091CR
Is there another way?
LAZORIAN
260CR
I always switch off the ones I can easily reach the power switches for first.
It puts me in a good habit when powering on, as those ones always get switched on last.
It's less of a problem with arcade machines than amplifiers or PA systems,
you get a lovely loud thump when forgetting to switch the speakers / amp off first instead of the devices attached to it. I've nearly blown speakers this way.
obcd
3,830CR
Arcade machines are designed to survive a power down by just removing the mains.
Mame based machines are a different story. Usually, nothing is done to avoid corruption of the drive when the power is removed. In such case, it's better to properly shutdown the operating system before you remove the power. Specially raspberry pi based systems are known to like to corrupt their sd card if you just power cycle. Some people have no problems at all, and others face corruption pretty much every 5 power cycles. It depends upon the brand of sd card and probably also depends upon the used power supply. If you have several arcades, it's probably a good practice to turn them on one after the other, as the inrush current can be up to 10 times the normal operating current. (There is a current spike at powerup as all capacitors need to be charged up to their operating voltage.) Since you ask for powerdown, it's probably irrelevant.
musashi
13CR
Thanks for the advice all much appreciated :)
My mortal kombat 2 machine has a separate power switch its kind of like a button the needs to remain pressed in to stay on so has been cellotaped by the previous owner with duck tape. I'm sure that switch isn't meant to operate that way?
As soon as its out of storage I can include pics which may be a while.
DanP
Administrator
2,232CR
Replace that switch. It shouldn't have a momentary switch there, someone has bodged it in. You can get replacement switches from Maplin for a couple of quid.
Personally I always power them down from the mains plug side, I've seen some hack jobs where the power switch on the machine will only power down part of the machine (say the main PCB) and leave part of it still powered (say the monitor). I like the 100% positive it's off feeling :)
Dan
5,414CR
Well I've been working on a Sega machine latley and for some reason the power switch in the front metal plate and been removed, put inside the machine behind where it should be and taped up. So I was assuming it was broken and had to be taped in to make machine stay on, but when I untaped it and tested with a meter its working perfect. only other thing is the maybe kids switched it off so they removed so they can't but happy its all good
I would guess similar, maybe the switch is faulty. Its worth checking these things though just for peace of mind you won't damage them turning off.
The machines I work on for my Job, they have a rocker power switch with a label next to it saying DO NOT USE
so when its crashed and they have hard wired it to the wallplate what you suppost to do, the staff often dare not touch it, one did the other week I assume and then the machine wouldn't power back up, had the same happen to me a week later and just need to switch it off again and back on but I bet they were worried lol
It probably says that on it because you should do shutdown on them from menu but sometimes you cant
Fuzzy
18 (100%)
583CR
Does the switch look like this?
If so, it's an interlock switch, designed to automatically power the down the cab when a door is open/off.
You can bypass this by pulling the switch OUT instead of pushing it in.
jonhughes
1,156CR
Is the back door missing from the machine? One of the reasons for taping the switch down is when the back door is missing. The switch is activated when the door goes on (door closes the switch - power enabled). No door and the switch stays open (no power). Apply duct tape to the switch and the switch remains closed (power enabled).
It's there deliberately to turn the power off if you are messing around in the back close to the monitor and you had forgotten to power off, or someone else came along, etc.
musashi
13CR
yes! that is the switch exactly. Do you know if that is a custom piece or was it an original feature of the MK2 machine at the time?
musashi
13CR
ok so its a safety feature thanks for that, I did remove the tape and put the back door on again, the switch does not power on as the button/nob does not go in far enough (no innuendo intended here peeps) I think that is why the previous user used duck tape.
Fuzzy
18 (100%)
583CR
It's a standard safety feature on most arcade cabinets.
Put the door back on (or pull the switch out - that's why it's shaped the way it is - so you can get a grip with your fingers) and the power will be restored.
I wouldn't recommend touching ANY of the electricals inside the machine if you don't know what you're doing, and the most important bit of advice is be aware that certain parts of THE MONITOR hold a substantial amount of charge (20,000v+) even when switched off / unplugged - do not go anywhere near it if you do not know what you're doing, and for goodness sake don't leave the back door off with children or other unsuspecting people around.
Fuzzy2017-05-25 13:16:41
musashi
13CR
thanks fuzzy I am a responsible person and the machine is not located anywhere public / accessible area.
The only thing I will be doing is changing a pcb over to check whether the colour issue is with my pcb or the monitor as recommend by another member.
