Problems with a Defender
Shaun1905
71CR
Can anyone help I'm trying to get my stargate defender working it used to work and now it doesn't
Any info will be greatly appreciated
Thanks Shaun
trm
2,877CR
I've moved this into a thread of its own because very few people will notice your post up here. Can you reply with some details about what it does now and what you've tried?
cheers
tim
Shaun1905
71CR
Thanks Tim,
It turns on makes all the right noises screen looks like a knitted jumper but it used work ok, it was it seemed to be set at all the maximums like the hardest level but with infinite ships/inviso/smart bombs
Do you know anyone that does home visits or anything like that
Shaun1905
71CR
I'm a complete novice so sorry but don't even know what that means, is it fixable ?
Anyone know of any mobile engineers
4,058CR
Yeah, course it's fixable. It means the PCB has a fault. If you don't know how to do it yourself then the best bet is to send the PCB somewhere to be fixed. There's a few people on here that do repairs.
Hopefully someone will see this and offer to look for you, if not you might need to ask in the wanted section for a Defender PCB repair.
bbz149
26 (100%)
1,608CR
I would check all the roms are pushed right in, also I would stick 2 small bits of wood on each side of the rom ribbon connector that's attached to the rom board and stick it in a vice, but only gently as you only want to press the ribbon cabel back into the connector
Shaun1905
71CR
I'm near sevenoaks/tunbridge wells
I know I'm going to sound like a bit of a dumbo but I don't know what the rooms are ?
mathj
499CR
this is a defender rom board, the chips with the labels on top are the roms
hope this helps
math
mathj2013-11-26 22:29:28
bbz149
26 (100%)
1,608CR
Rom board below. I would remove the board, note the ribbon cable is fixed to the board so you have to remove the connector from the main board. Lay it flat on something hard and press all the roms into their sockets. I fixed my spare board-set by repressing the ribbon cable and repairing a broken leg on a rom. Bottom Right of pic is ribbon cable
