PSU Amps
dj_yt
787CR
Is there a reliable way of determining the maximum amps my PSU can handle on the 12v rail? The cab is an Electrocoin Midi, but there are no obvious markings on the PSU from what I can see.
simonden
20 (100%)
1,042CR
silverfox0786 said:
a stock EC midi Switching PSU is 7Amps on the 5V line and 2Amps on the 12v i think
i have one in the loft so i can check it later if you want
Close - it is 7a on the +5v but only 1a on the +12v.
dj_yt - if it is a stock PSU (PEM-710Z) , then the markings are on the label just under the model number.
dj_yt
787CR
Many Thanks! I was expecting it to be around the 2 amp mark. Back to my original question - how can you tell if the PSU isn't marked? :)
I may swap it out so I can fit a more powerful version of 2huwman's Jamma PCs... which would need 4amps
dj_yt
787CR
I'd ideally put in something like this:
http://www.arcadeworlduk.com/products/Black-Arcade-JAMMA-Power-Supply.html
Presumably could just swap out the original PSU then.
Idea being that I'd still want to use my Jamma PCBs too.
I can't see any markings at all on the PSU in terms of model number or make. I was going to remove the PSU cage to check the PCB markings, but one of the screw heads is borked - so I decided to hold off for tonight! :)
dj_yt2015-11-24 22:41:14
