PSU wiring
J69
281CR
Took delivery of an LS Sound today. Looks like it's had an aftermarket Jamma loom installed. There's lots of static off the metal bits and a distinct lack of frame grounds!
Also, are the grounds supposed to be wired like this on the PSU? I assume FG needs a wire grounded to a bolt in the cab somewhere? Although there are pictures online of other PSUs wired this way.
The +5v and GND wires are also warm, which I've not noticed on other cabs before? Is that normal?
J692022-07-18 20:38:18
Ace`
PlanB contributor #1
40 (100%)
4,032CR
FG should be connected to earth (green/yellow wire, top pin on a 3 pin plug) and all the metal parts of your cabinet.
A single ground, 5v and 12v wire for a jamma harness is a joke. That harness needs to go and replaced with a good quality one. Or at the very least far more power and ground wires added.
FrancoB
16 (100%)
1,040CR
100% this. The single thin wires will be acting as a resistor, hence them getting warm.
No doubt its a cheap chinese loom to boot and the core conductors are thin with thick insulation.
cliff_poole
1,069CR
I agree with others about more substantial cabling.
The zappy bit is actually quite a good sign that the cab is earthed properly. It is your body that carries the static charge, when you touch a metal bit of the cab, it discharges to earth causing the shocks. I'm guessing your carpet is fairly new. If you look online, I am sure there is some sort of mixture you can make up and spray on the carpet to reduce static.
Mykill
229CR
I think your frame ground is connected to your signal ground, their should be an earth wire from the wall to fg ,I don't think the blue wire is right , what's the green and yellow wire in the background connected to,fg is a safety you have no safety
If the psu failed and dumped 110220 into the blue wire it would travel to the 5v/12V side and then to the switches,game board,,,who knows what would happen.
Mykill2022-07-19 12:37:58
J69
281CR
It's a trick often used to prevent screen interference apparently. I'll check where the earth is grounded too. Looks like there's only L/N coming off the transformer into the PSU
J69
281CR
muddymusic said:
I had one of these years ago, just looked up the pics I took of it and it was exactly the same inside!
Where did yours end up? This one has an Arcade Club sticker and reference number on the back.
It's in decent nick. Good screen and no cracks in the plastics. A bit of magic sponge has cleaned it up well
BulkSlash
81CR
My JAMMA cab has that ground to FG too, I'd never seen it before and I left it off after replacing the PSU and wondered why I was getting screen interference. Gunblade suggested I put it back and that sorted it right out.
2,264CR
I really can't remember, it was a very long time ago I owned that. Back when I only had one cab
I wondered if it was the same one, hard to tell really. It was near mint.
