Qbert - No speech
Munkeycop
15CR
Hi guys. I’ve got a Qbert cab that seems to play the standard sounds and music ok but there is no speech.
I’ve had the sound board out and checked the contacts all over it (seems fine). I’ve also taken out the SC01 chip and given the pins a little clean. Still no joy. I’m guessing the issue lies with SC01 chip but is there anything else I can look at first before going down the route of replacing it?
I’ve also had a look at cademo’s flow chart.
I’m a huge n00b at this so any suggestions are welcome.
philmurr
48 (100%)
2,374CR
Check the inputs to the SC-01, and see what's happening on input pin 7 & output pin 8.
If you have an audio probe then check the analogue output on either of pins 20/21/22.
It may even be something simple such as potentiometer R16 so try adjusting that.
SC-01's are made of unobtanium, so hopefully the fault lies elsewhere. If it is faulty then best of luck finding a replacement.
Munkeycop
15CR
Thanks for the response. I had a feeling that the SC-01's were rarer than hen's teeth hence why I'm trying to check for anything else that could be causing the issue.
Couldn't see an issue with the inputs/outputs as suggested. I don't have an audio probe so no joy there. I had a look at the potentiometers as suggested, still nothing.
I read somewhere about A10 on the main board so I took that out for a clean and popped it back in, didn't make a difference.
Not sure if it's related but I put the cab into test mode and ran the memory check. There was an error on 'Ram 3' but my Google searches about what this means are proving fruitless.
If anyone has any other suggestions I am all ears.... well, eyes. Cheers.
SUPERSPRINT
1,035CR
Few things to check. Firstly that the voltages are correct on the power supply, is it outputting the correct voltages?. Secondly it wouldn't hurt to recap the sound board if you haven't done it yet, if you do need to get hold of a an sc01
Kevin at game room repair should have stock.
http://www.gameroomrepair.com/ICparts/ICparts.htm#SC01A
Munkeycop
15CR
Awesome. Thank you
