Questions about Candy
Mr20to5
1,366CR
Hi guys,
I appreciate that I have asked some questions about Candy Cabs a while ago, but that was then and this is now. Plus I am also (having just sold a cab and saved some pennies), now, up and ready to buy my next cab, as opposed to the speculative post I put out a while ago.
So, I am fairly sure that I would like a Sega Candy, please don’t ask me why, I just love the look of them and I think it’s as simple as that.
From a complete spectator’s viewpoint having never owned a candy of any flavour these are how I rate the Sega’s;
Astro City – I just love the way this looks, but it’s the oldest model of my trio, so is it still great/good/or could do better.
Blast City – Not as much in love with the looks, but then there’s a tri-sync monitor in there….
New Astro City – Again love the looks, but they always seem very prone to yellowing – especially around the speakers
So now that I have shed the entirety of my technical expertise, I was looking for a few opinions and answers to these questions;
1. I intend to play mainly mame or actual PCB on the cab, no console emulators or pad-hacks (whatever they may actually be). So not sure how this effects which type of monitor/cab combo I need.
2. NOOB ALERT !! So, as it’s a little onerous rotating the screens in any of the above, I probably won’t that often. But when in mame, you are swapping between all manner of games/orientation – so…………. I take it if the monitor is sent for say horizontal, then I can still play vertical games, without spraining my neck to on side? With the game just having black border to either side?
3. If indeed my theory above is correct, and if I’m playing 50/50 between hori and vert games, which orientation work better? Playing vert on a hori monitor or the other way round?
4. The step down transformer. Is there a go to brand? Or am I just popping down to Maplins? Do they need any specific features?
5. Lastly, there is a possibility of grabbing one fairly local to me. I drive a Peugeot 3008, SUV type thing, which is fairly cavernous with the seat down and boot has a split rear door with loading shelf, which makes sliding things in fairly easy. I’ve had a full size cab in it before (Zaccaria Invaders), so no issue with the size, but with these cabs having such a behemoth of a screen that probably weighs as much as I do, are there any issues with lying these on their back/side? Or is it something that needs to stay upright? As I would rather know now and just use Martin/hire a van.
Think that’s all, thank you in advance for taking the time to read through and any answers/advice you can throw my way.
Please fee free to add any personal views over which are best/ones to avoid.
JohnnyChaos
Blows own trumpet for CHQ cabs
325CR
Couple of quick answers.
Astro and new astro are basically the same but the nac has improved audio. Both are fine though.
The blast is a fraction wider so that wouldn't fit In my house without removing the cp, so something to bare in mind.
You can play vert games on a hori screen using mame. But not normal arcade boards and astro screens are very heavy.
Without the screen in I can lift a nac. And took one upstairs by my self. So you could look at taking the screen out and put it on your front seat for easier transport. Just careful you don't scratch the screen.
2,266CR
I've been through a fair few candy cabs now. My best advice for you is
go for the one with the best picture quality - and I'd take a bit of
burn with perfect geometry over a burn free but poor quality tube every
time now. When you're sat at the cab it's all you'll see, 29" right in
your face needs to be spot on. All the Sega candy cabs (Astro, Blast,
Naomi and so on - not Aero though) use the same control panel shape so it's easy
to get different ones, and new ones are still easy enough to find.
Rotating the monitor is a pain. Get 2 cabs, that's the best answer. Have 1 in hori 1 in vert, problem solved.
I suppose you need to ask which games you'll be playing, no need to go tri-sync if you're only playing 15k games. If you're going for a Blast and want to go for 24/31k games make sure you get the JVS loom and full Jamma loom so you can play more stuff. Also some of the psu's don't put out -5v which cuts out quite a lot of older pcb's unless you fit a negatron so that's something else to check.
tronads
455CR
Just a thought about the transportability and getting them in the house.....the Blast is 1000x easier to remove the control panel on. Its 4 bolts and 2 screws, and 3 wire loom connectors to pull apart, and it just lifts off. The other cabs you pretty much have to seperate half the casing to remove it.
This makes a huge difference getting it in a standard door, or in a car.
The blasts do seem far less prone to yellowing aswell, certainly that was the case when I went to buy mine and looked at about 50 candy's, and you could spot ablast a mile off compared to the others as they were all gleaming white.
