Quick 19 in 1 question
virtvic
The Cabaret King
21 (96%)
2,012CR
Asking for someone not in here yet -
Is screen flipping (dip switch 1) supported with using an lcd monitor in vga mode (dip switch 2)
He says nothing happens when using dip switch 1?
Flinnster
The Dino King
29 (100%)
2,566CR
No idea I'm afraid, only tried mine in std Jamma cabs. I can lug a VGA monitor into the same room if nobody with a VGA monitor comes forth
Fantazia2
2,246CR
jengineer said:
Try dip switch 3?
On the 60in1 #4 is for high score saves,
Are you sure about that, according to the manuals both are the same.
#1 Flip
#2 15k/31k
#3 High Score Save
#4 Test Mode
I will dig mine out in the morning and give it a try.
Although Which bit do they say does not work, as dip 1 just flips the screen i.e. if you have put the monitor in upside down on a horizontal, more use on the vertical as screen can be installed on either side.
There is an option in the test menu to setup the cab type to upright or cocktail with either 1 or 2 sticks, is it that setting they need?
virtvic
The Cabaret King
21 (96%)
2,012CR
No - the guy has an lcd mounted vertically in a cab and is using the dip to use VGA and dip 1 doesn't change the orientation whether it is on or off. I suggested bridging the points under the switch in case the switch was faulty, but it doesn't seem to work - maybe a faulty board somewhere?
smarty
Ready Player One
1,305CR
Do the controls need to be set to 2player like on a 60/1 for flip to work?
You can see if the dips work by holding ‘service’ Button at boot it takes you to a page where button/dip status is shown.
jengineer
49 (100%)
1,205CR
Just re read your post about him having it vertically
The guy will need to mount the screen horizontal because it’s a horizontal board
If you do manage to flip the screen it won’t flip it 45 degrees, it will flip it 180jengineer2018-01-14 10:11:38
big10p
Coins detected in pocket!
6,091CR
jengineer said:
I'm guessing he has the screen vertically and was trying to flip it 45 degrees
Indeed. The 19-in-1 is a hori board, so if he has a vertically mounted monitor, that's a bit of a fail, right there.
