Quick lecky advice
biglouie
84CR
Evening UKVACers
Could I ask your advice please?
I'm making a quick arcade bartop (I want to start putting some scores in to Vic and Shaun on Ten Pence podcast so I am making a Mame machine using a Pi3)
I got this far on Saturday (15mm Baltic birth ply on the sides and CP, everything else is 12mm birch ply)
Anyhoo....Lektric...
I need to give the Pi, 2.5amps and a few 5V LEDs in a strip at the top, probably about the same, mayber slightly less, will only have 5 or 6.
So I planned to put a switching supply in, that will convert 220v to 5V, 3amp.
QUESTION: With the lecky, if I have both Pi and LEDs connected to the 5V 3amp terminals, will they both have 3amp available to them, because they are running in parallel, not series? OR if they are connected to the terminals, will the Pi take what it needs (up to 2.5 amp) leaving leftovers for the LEDs...
i'll need to power the LCD with 220v direct from the main switch before it gets to the switching power supply I guess...
Stoopid question no doubt. Wish I'd listened in physics lessons now, instead of dicking about until it was time to go the chippy and play Galaga...
northwest
119CR
Can't you use a multi USB plug ? Seen ones with 4 USB on that each has 3a , you can get USB powered led strips for the other terminals ? Just an idea bud. Nice bartop by the way .
biglouie
84CR
...good idea....
I'm going to try one of these too. Planning on making a few bartops, so will be handy.
What were you thinking on the USB. Something like this ? https://www.amazon.co.uk/Charger-RAVPower-Technology-UK-Adapter/dp/B01LAGOYUO/ref=sr_1_3?ie=UTF8&qid=1484037730&sr=8-3&keywords=multi-usb+plug
OR, now youve got me looking...
Why not this actually...
https://www.amazon.co.uk/Te-Rich-Extension-Protector-International-Detachable/dp/B01F768X5K/ref=pd_sbs_107_3?_encoding=UTF8&psc=1&refRID=8M0WCEJ5FMPMW6YY08FN
That does the power for the monitor and includes the USBs BUT I think the US+B output ought to be at least 3amp each, as the Rpi3 needs 2.5amp to operate, and I'd rather give it slightly more than it needs.
Question still stands about the parallel/serial question though :) I just want to know..
biglouie2017-01-10 08:56:46
obcd
3,830CR
If your power supply is 3 Amps, that's the maximum it can deliver. If your Pi needs 2.5 Amps, you have 0.5 Amps left for the led strips. In parallel, all devices receive the same voltage. In serie, the voltage is divided. The device with the highest resistance will get the highest voltage.
If a usb power supply has 4 outputs that are marked 3 amps, it probably can't deliver more than 3 amps in total. A 12amp supply is more the size of a laptop adapter.
Most USB to "micro usb" cables only have very thin wires that are not designed for 2.5 amps. You might better look for an adapter with integrated cable. Those only have the 5V and GND wires which are much thicker. Just buy a separate 5V 1.2 Amp adapter for your leds. They are like 5 bucks if you look for a raspberry pi adapter.
Do your homework about powering down of the raspberry pi. If you simply unplug the supply, it can corrupt the sd card. You either need a separate power down button which you activate before you disconnect the power or you need a "read only" root file system on your sd card.
If you only have 5 or 6 led's to power, you can use one of the pi usb connectors for it's supply. A normal led shouldn't need more than 20mA, and ledstrips usually have 2 or more led's mounted in serie.
If you use the pi3 with graphics (which you will), you might consider buying and mounting a small heatsink for the cpu. We had one showing a webpage, and it was becoming real hot without heasink. It slows down it's clock when it heats to much, but that's not ideal for gaming.
biglouie
84CR
Thanks for the information obcd... Much appreciated...
I think I need to work out volts and amps! A 5V supply kicking out 3 amps...If two devices are plugged into that terminal, will they both have 5v and 3 amps available to them? Because they are in parallel?
Looking into powered USBs...These do seem a good option, with a couple of UK 3 pin plugs on them and 3 USBs...BUT as you say, this is confusing, as they state that the USBs are 2.4 amp (for example) but whats hard to ascertain is if thats 2.4amps available at each port, when you have 3 devices plugged in.
If its max 2.4 available on each, then thats great!
My education continues...
obcd
3,830CR
They will both have 5V, but shouldn't use more than 3 Amps together.
A normal USB host connector is suposed to be able to deliver 0.5A.
Some self powered usb disks need more current.
On some pc's, it's not a problem as they combined the usb port power output.
You can extract 1 Amp from 1 connector or 800mA from 1 connector and 200mA from the other.
On other pc's, it really is limited to 0.5 Amps on one connector. That's why some harddisks have a cable with one plug on the harddisk side and 2 on the pc side. Using both connectors they can again use the current from both usb ports.
As I told before, I doubt the 3 ports will be able to all deliver 2.4 Amps at the same time. That 2.4Amp will likely be the maximum current for the 3 ports.
biglouie
84CR
I think I understand.
The device I am basing it on is this..
https://www.amazon.co.uk/gp/product/B01GX7V5F2/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
I am thinking I can have that wired into the cab and that will allow me to easily have a three pin plug for the monitor at 220v and a three pin plug for the power supply that came with the pi (might as well use that, it delivers 2.5amp to the pi)
And then the USB ports can be for the LEDs & power the HDMI to VGA convertor. OR the USB can also power the pi if I choose not to use the power supply with it.
Regardless, the bit they claim is this as follows. Remains to be seen if it really can do that :)
  • ?Multi Charging Station?The J-Bonest Power Strip features 2 UK outlets (with Over-current Surge Protection) and 4 smart USB ports, auto-detect your devices and seek to maximize the fastest possible charge speed, each up to 2.4A. ( Include 1 pc UK Detachable Power Cable, 100-240V 50/60Hz)
RSwanson
205CR
That all seems fine to me. Remember what obcd says though.
I used 2 RPis for my home central heating for a few years, a couple of power cuts and they died. Infact, because of that I got so fed up of using them and moved on to something else.
They are incredibly prone to sdcard failure if not powered down properly.
Sort out a safe way to power down (or battery backup), or do a read only filesystem like he stated.
