Raiden 2 battery
mysticmonk
1,051CR
Have had a raiden 2 for donkeys years and have always been suspicious of the battery (red original)
So, about 50 years later, I actually had a quick look into it. So its not a suicide battery per se, but some suggest that if it dies the ability to save high scores is permanently lost.
Couldn't find a confirmation of that. Anyone here know what it actually does?
Monstermug
1,807CR
ive never replaced it because i dont know what that small battery connector is called and original oem red batteries are impossible to find. didnt feel like hacking one in place thats all.
TWB
318CR
I have a Raiden 2 board that has had the battery removed and seems to work fine, scores aren’t saved after switch off bu5 I don’t remember if they ever were, does yours currently save scores?
There’s one on eBay at the moment that looks like a battery was never fitted.
GadgetFreak
963CR
Only had a quick look at the code but my opinion is that high scores were never saved though I could be wrong. The code that sets up both HS tables is at $99E3C and the tables are at $9DD4-$9EC3.
But I have not seen any condition code that bypasses this setup in some cases which leads me to think it has never saved them. There is empty unused ram at $BF00-$BFFF where scofres could be preserved if an NV ram was put in the board.
The biggest problem as always is working out which ram needs to be changed. The board seems to have 6 x 2K ram, 2 x 8K ram and 4 x 32K ram. Most likely I would think that it would be one of the 32K chips that needs to be replaced. There are not many types of 32K NV to my knowledge, though I have some FM1808's but these can be a problem depending on how the board controls the ram. If the schematics are around it may be possible to identify the correct chip.
Lastly, I don't have a Raiden II which would make it difficult for me to do this mod confidently.
virtvic
The Cabaret King
21 (96%)
2,013CR
Now that GadgetFreak has said this, it jogged my memory into thinking that the battery only saved PCB settings? Hmm?
I can loan you my pcb if you wanted to have a go at modding it?
Monstermug
1,807CR
All this just from a quick look (probably at online pics too!). That's amazing.
