Raiden 2 sprite problems
2huwman
375CR
Does anyone have any suggestions as to what might be causing the sprite faults with this Raiden 2 PCB? The sprites are just big solid coloured squares. Video and pic here:
https://photos.app.goo.gl/MKjb69TE3rYYcWzY8
The background and text all look ok. It looks like there are various custom and surface mount chips so might not be an easy fix I fear.
Thanks for any help!
2huwman2020-07-21 13:41:22
TheDaddy
14 (93%)
7,230CR
Looks like a ROM issue (Could be wrong) - Have you pulled cleaned and refitted socketed chips ??
Dave.
P.S It could be mask roms looking at the board.
TheDaddy2020-07-20 16:25:00
2huwman
375CR
Thanks Dave - haven't done anything to it yet but that sounds like a good start. I'll see if that makes any difference. Wasn't sure if these boards had any kind of suicide battery?
Ace`
PlanB contributor #1
40 (100%)
4,040CR
The battery is just for scores, I'd start by checking the four object maskroms in the middle of the board and make sure there's no lifted pins on the two large customs. Awful hardware to work on, good luck.
2huwman
375CR
Thanks guys - I've cleaned and reseated the socketed roms with no change.
The four object maskroms in the middle of the board arent socketed - i guess there's no way of checking them without desoldering them is there?
2huwman
375CR
Actually, on closer inspection, the first few pins on SEI252 were bent and pushed up against each other. Pin 1 and 2 were also lifted. I've gently separated them and pushed them back down and now the graphics problems are different (more scrambled sprites but the 'Raiden II' title graphic is now visible.
https://photos.app.goo.gl/ZgQtDoizgaEZvQe58
So I guess it's this custom that needs repairing.
trm
2,877CR
Someone has probably dropped another board on there which was stopped by the QFP.
You'll probably fix it by reflowing the solder on the legs of that IC - pushing back into place won't make a sound electrical connection unfortunately. If enough force was applied to it it's probably torqued more of the legs so they're not making a solid contact.
IronGiant on here does board repairs, but I don't know his availability or whether he touches stuff like this. Worth a PM to him to check though.
Good luck!
