Rainbow Islands sprite issue
lethargyman
59CR
My Rainbow Islands PCB has developed an issue with sprite flickering / corruption, particularly when there's a lot happening on screen.
Is there anyone here would be able and willing to look at the board? For the 'going rate' of course
If it's an easy fix I *might* be able to have a go myself, but set your expectations very low for my diagnostic / repair skills
lethargyman2021-08-20 19:01:15
Phils Arcade
1,530CR
On quick first glance, looks like either a badly set ROM or RAM issue.
Have you tried carefully removing the ROMs. Cleaning the legs lightly without breaking any and resetting them back into the board? Sometime the legs can oxidise or be dirty and no longer make good contact.
RAM is a different issue altogether.
lethargyman
59CR
Thanks Infurious. I'm still yet to replace a ROM of any kind, but I've been meaning to pick up a set of IC tweezers for another job, so I'll give that a try. I'll find a different board to practice on!
lethargyman2021-08-20 20:08:28
lethargyman
59CR
badgerme said:
VectorGlow / Phil is your man - he did a cracking job at fixing the faulty ram on my Rainbow Islands PCB
Lovely guy! Send him a pm
Thanks! I'll try reseating / cleaning the legs first and if that doesn't work then I'll see if VectorGlow's willing to take a look
lethargyman
59CR
Fixed! You were right about it being a badly set ROM issue Infurious. This turned out to be embarrassingly simple to fix as my PCB is one of the ones with a daughter board with a single ROM chip on it. That board just needed to be reseated, so I didn't even need to remove any ROMs. Working perfectly now
