re centipede trackball.
LukeWells
334CR
[uk-vac] re centipede trackball.
Well Andy any suggestions on the trackball then? The POKEY is poking
away fine soundwise, so I assume them to be ok
Luke
> 1) no, the Leta runs on normal voltages
> 2) centipede doesn't have a LETA, it uses the POKEY for trackball
input.
> 3) the LETA first appeared on Crystal Castles i think.
> Andrew Welburn
d-type
172CR
RE: [uk-vac] re centipede trackball.
I've had just the trackball input part of a POKEY fail.
Try swapping it out for a known good one.
My centipede PCBs have been through 4 or 5 POKEYs in the last 3 or 4 years.
D-T
d-type
172CR
D-T
spankweaseluk
0CR
Oddly enough I have a similar problem.
I had a millipede board repaired which had a sprite/collision problem.
When the board came back from repair, I didn't plug it for about 6 months.
When I eventually powered it up, the initial problem was corrected and
everything looked fine, but I found I was unable to control the head/archer.
The symptom was a juddering head when the track ball was moved. I did not
pursue the issue with the repairer.
I'm now wondering whether the board was tested with a joystick which didn't
highlight with the control problem with the trackball.
Is it possible; I may have the same problem as Luke?
In which case, can anyone supply 2 x (known good) Pokey chips?
I'll pay the necessary fee + postage and handling.
Regards,
Paul
spankweaseluk
0CR
Regards,
Paul
d-type
172CR
I get mine from www.mikesarcade.com. Last time he charged me the same
postage as the US rate, although I was buying a large handful of them.
He's always given me good service. He sent me some wrong EPROM once, and
insisted on sending replacements and that I kept the incorrect ones as well.
D-T
(Service levels can go up as well as down. Always seek professional advice
before investing in old arcade shite. Preferably from a psychiatrist.)
d-type
172CR
D-T
