RE: [ukvac] [Tech] How to test for sound problems
Heh heh! Uh oh! The infamous Phoenix 'OMG how do I replace the melody
chip' syndrome!
Well check the archives for information on using those melody bell chimes
for your Phoenix! Joke! Well actually almost a joke, as they do indeed use
the same chip!
Anyway... Enough humour, how to test what's gone wrong for missing audio:
Using a multimeter check the edge connector for ALL the power connections
(of course +12v is the important one here, but seeing as we're testing, hell
test 'em all!)
Now arm yourself with pinouts of the amp, find the VCC and check that it is
being supplied with +12v, check continuity with ground and lastly measure
the voltage on the output. If the output is non-existent then check the POT
(or just check the POT anyway...) and check the amps input/inputs. I
believe Phoenix just sends a signal to the melody chip and it plays quite
happily all by itself, bit like pressing a doorbell funnily enough... If
you have output but its weak, then the amp itself is probably at fault - if
you have a nice output but it doesn't make it as far as the edge connector
then trace where it goes and find where it stops...
Check those capacitors that are in the sound circuit. If you're not sure
they're okay, then just replace them all. You'd happily cap a whole monitor
if its faulty, why not a sound circuit??!!
A handy tool is a logic pulser, which can be used to test the amp.
When testing an amplifier, the process is to start at the output and work
your way towards the font-end.
In this way you can use the speaker to determine if each stage is working.
If one channel of a stereo amplifier is faulty, you can use the good channel
to provide a reference. Turn the amplifier ON and start at the output by
injecting into the speaker. As you work your way towards the input, the tone
from the speaker will increase. (Okay so I cut and pasted that bit, but I
couldn't be arsed to think of how to put it and I knew where that link was!)
If the amp appears to be good, then suspect the PROM/ROM which holds the
sound data, if its socketed then remove it and clean it (check the socket
while you're at it) check to see if it or any other part gets hot while the
game is running and replace it (yeah I know, easier said than done most of
the time!) Obviously, if working the sound amp will run hot that's why its
often got a dirty great heat sink attached to it!
Good luck! ;oP
Pobster
PS. Any critisms are welcome, any revisions ditto, any flaming because I've
missed something or got something wrong then just remember I'm no
technician - but no-one else volunteered any information...
chip' syndrome!
the same chip!
test 'em all!)
Good luck! ;oP
Pobster
