Re: [ukvac] [Tech] How to test for sound problems
> If the amp appears to be good, then suspect the PROM/ROM which holds the
> sound data, if its socketed then remove it and clean it (check the socket
> while you're at it) check to see if it or any other part gets hot while
the
> game is running and replace it (yeah I know, easier said than done most of
> the time!) Obviously, if working the sound amp will run hot that's why
its
> often got a dirty great heat sink attached to it!
> Good luck! ;oP
one problem.
Phoenix has a completely analogue sound circuit
each individual noise is
made up from individual sound circuits that are simply triggered by the game
logic... not 'sound data stored in a rom/prom'.
Paul swan wrote a good phoenix sound fixit guide i think...
I know phoenix sound circuits inside out and have everything mapped out if
need be, but the preliminary part of pauls advice rings true if all sound
dissapear..
the LM324's and the main LM380 sound amp are the first ports of call if
_all_ sound disspaears.
don't laugh, but its possible to pick up radio stations on a faulty phoenix
sound pcb.. a most haunting experience
Andy
the
its
> Good luck! ;oP
one problem.
dissapear..
Andy
