Re: [ukvac] [TECH]Space Invaders cocktail to upright conversion problems
At 09:17 pm 8 11 02, you wrote:
>Next I modified the pcb, as detailed here:
>http://easyweb.easynet.co.uk/~swan/arcade/pv-ur.htm
>(Inserted the three jumpers also cut the track from pin 9 IC7 going to IC1,
>and put it to ground instead.)
>Put in the cab again, now everything was upside down and the left, right and
>fire didn't work.
Did you set the three DIP switches as well (5,6 and 7)? This is important!
>Now I've remove the three jumpers, tested again, the controls work again,
>but everything is still upside down.
Those three jumpers just gang together the controls for P1 and P2. By
turning off the three DIP switches you disconnect the P2 inputs to the
game. One the jumpers are in and the switches are off the game will now
always use the P1 controls no matter who is playing.
>Any help gratefully received as I've spent the last 5 hours doing this and
>am getting slightly fed up now!!
When Paul gets you to fit the jumper IC 7 pin 9 ... it goes to
ground. This signal controls which way up the screen is. By disconnecting
the input and forcing it to ground you are making it always the same way
up. To reverse the direction permanently you need to pull IC 7 pin 9 high
(ie 5v).
Hope this helps!
Dave Langley
www.robotron-2084.co.uk
>fire didn't work.
(ie 5v).
Hope this helps!
Dave Langley
