Reading BPROMs
rtw
24CR
A mate of mine is dumping a PCB and with the following devices:
63S281
82S129
82S135
Sadly his current programmer does not support them, so he wants to buy an extra one.
Does anyone know the cheapest programmer available which can read these devices ? Or have other clever solutions ?
VectorGlow
34 (100%)
900CR
The only type that I know of is the Data I/O 29B with Unipak 2B (which is what I have) - it's a very old programmer though and I guess they aren't cheap these days.
Mark Haysman (posts here as retroclinic) sold it to me years ago and he has his own. I think he actually restored it to life. It's possible that he still has one for sale, you never know.
This is the programmer on his site:
http://www.retroclinic.com/leopardcats/dio/dataio29b.htm
No doubt there are other old programmers which will do the job but I doubt if any new ones handle the old BPROMs. Then again, maybe somebody has created or modified something fairly new that will handle them?
porchy
994CR
My Dataman programmer can do the 82s ones but seems to struggle with the equivelant versions of them.
If its just reading them out then it could easily be done with a homemade adapter and reading as an eprom or an arduino and bread board would make short work of it too
rtw
24CR
Thanks for all the tips lads, yeah this is just for a readout so maybe an Arduino could be used. Would be sweet if the GPIO on the Arduiono could be used as a generic pin driver i.e. use the GPIO to power the BPROM.
porchy
994CR
the current draw would be way too high to power from a GPIO but the dedicated 5v output pins should be good enough. Ive done this for PAL chips.
rtw
24CR
I was afraid of that, would be so much easier to make a generic dumper if you could reconfigure the positioning of 5V on the fly.
porchy
994CR
depending on how configurable you need the +5v supply its not too difficult to implement. My arduino PAL pcb does it for 20 and 24 pin devices (albeit very 'hacky')
albeight
abaxas
124CR
I bet an hour with a breadboard, some wires, an arduino uno and a pc and you would have all three dumped.
Why build and adapter, you can use use wires for that.
rtw
24CR
I have an Elnec Beeprog 2 and can read them no problem, it's for a mate of mine who lives far far away who would not be comfortable with wiring this stuff up so I need a turnkey solution.
philmurr
48 (100%)
2,378CR
rtw said:
Indeed he did very clever "reverse" use.
Are the replacement EPROMs fast enough to simulate a BPROM ?
Replacement PROMs I've tested are stated as being 45nS access, original 82S123 & 82S129 BPROMs were 50nS
rtw
24CR
Ah my bad seeing the words 27c256 I assumed they were EPROMs.
I'm wondering what kind of speed you would get with a CPLD ? If you use a device like an EPM7064 that should be 5V capable. I'm not that familiar with CPLDs so I do not know if 1250 gates could mimic a BPROM
Battlezone
410CR
The nice thing is that Phil already went to the trouble of building the PCBs. :)
Once you've built the little adapter with a socket on it you can test any future
suspect 82S123 chips in no time at all using your existing programmer.
The 82S129 board may be reversible too (but I haven't tried that yet).
You can bread board them each time or Arduino them if you like.
rtw
24CR
The PCBs look sweet and I would not have any issues using them but I need something "out-of-the-box (R)" which my mate can use.
rtw2016-04-25 11:01:35
rtw
24CR
Battlezone said:
KmanSweden said:
Don't know if you've found this yet: http://www.jammarcade.net/mad-gear-repair-log-aka-reproduction-of-a-bprom-to-gal/
That's a great little creative fix for a missing PROM.
Yes I already found Elgensrepairs
It's a very novel fix!
rtw2016-04-25 15:32:55
