Reading/Identifying Proms
mickyc22
67CR
I'm a total beginner in reading eproms/roms/proms etc so after some basic advice, apologies if i use the wrong terminology below, please correct any mistakes i make.
I have bought a universal programmer in the hopes to verify and if necessary burn new ones
I have an issue with my MK2 sound board so far I've managed to read in and verify U2 which is an eprom which i could easy identify and read in.
With U3 to U7 i believe they are custom midway Proms and have no idea how to identify them for the reader to scan them, how do i go about this?
Many thanks
jonhughes
1,156CR
The MK2 soundboards can be OTPROMs U3 to U7 (with U2 a normal ROM) or all ROMs (U2 to U7). When they are all ROMs they are all M27C4001. Try reading the OTPROMs as M27C4001 and see if they read.
However, if any of the OTPROMs are bad there is an error tone when the soundboard boots, which can be found in test mode also. If you're getting no sound on boot it's likely to be something else than the ROMs.
Has the sound worked before and has just stopped working?
jonhughes2021-10-03 21:48:06
mickyc22
67CR
Thanks i will try reading them as M27C4001, may i ask how do you know this just experience? as i tried to search up the numbers on the proms with nothing coming up as to what they are.
The sound worked fine then one day nothing, the service menu states all is fine i get the one tone saying its ok and the irc checks out fine too, board voltages are fine, i've replaced the caps/amp/DAC/clock crystal, im sure the chips are fine i just like to 100% verify that and now i've purchased the reader like to clarify this. will let you know how i get on, if you have any further advice it be greatly appreciated.
jonhughes
1,156CR
I own and have repaired several MK2 and MK1 soundboards. I have the ones with OTPROMs and with standard ROMs. MK2 soundboards can be very picky and as you mention the test tone (one tone) indicates everything is ok when it's not.
The soundboards can be really picky. Bad ribbon cables, oxidation on header pins and power pins, not straight header pins, odd voltages can all produce faults even when there's nothing wrong with the PCB.
Joker CK
74CR
Just a thought, but have you tried reading the chips as m27c4001 with the eprom reader I.D. check turned off? The pinout will likely be the same but if the chip I.D. isn't a match the software won't recognise it. If you turn off I.D. check it should read.
mickyc22
67CR
Many thanks thats worked, i dont claim to understand why but thats awesome.
When it comes to reading other types of chips how do you know what type to select is it just down to knowing or is there some lookup tables?
cheers
Joker CK
74CR
No worries. Each eprom has a manufacturer ID coded in so the reader looks for that first and if it doesn't match what it expects, it won't continue the read process. There are a few different versions of essentially the same eprom by various manufacturers, ST, Texas Instruments etc, whose pinouts and functions are the same, but the software won't read it if the ID doesn't match the chip in the device. As for how you know which chips to select, you can just Google the chip name and 'equivalent' and you should find some resources which will list all the chips that are essentially the same. It's always best to double check that the pinout is a match by googling the datasheets and ensuring the pins are the same, otherwise you risk frying the chip by potentially sending voltage through a data pin.
