Relay advice, please
big10p
Coins detected in pocket!
6,093CR
I won't complicate things with details why, but I want to switch on a monitor using a 12v switch connected to a relay, but not sure exactly what relay to get. Needs to be a standalone relay that can be mounted to the base of the cab, that has screw terminal connections for live & neutral input/output and the 12v coil voltage. Think I need a NO DPST relay? Any info, advice and links to where to buy much appreciated.
Cheers!
big10p2019-03-24 20:45:45
SUPERSPRINT
1,035CR
So, you can use a standard electrical 8pin mini relay and base, rated at 5 or 10amps, which should be fine for your monitor.
Bases are generic and the relays come in various flavours.
Here’s one with a 12v dc coil, just connect the live and neutral through the normally open pairs of contacts and hook up the coil a1 and a2 to the 12v dc feed.
https://www.ebay.co.uk/itm/DC-12V-Coil-Power-Relay-LY2NJ-DPDT-8-Pin-HH62P-JQX-13F-With-Socket-Base/292033343105?_trkparms=aid%3D555018%26algo%3DPL.SIM%26ao%3D1%26asc%3D20180306143914%26meid%3D15984e8278384256b89339ee0db4eb67%26pid%3D100935%26rk%3D1%26rkt%3D12%26sd%3D202623833212%26itm%3D292033343105&_trksid=p2349624.c100935.m2460
obcd
3,830CR
In such case, it's not really needed, but it could still minimise small sparks that might occur during switchover. It could help increase the switch lifetime, but likely you won't need it.
big10p
6,093CR
Got the relay in the post today. Noob question: what's the orange, spring-loaded tab on the bottom for? Looks like it's something to do with the 12v coil terminals?
SUPERSPRINT
1,035CR
That’s a manual switch to test the operation of the switch. Without the 12v line you can manually test if it makes contact. I find that it helps when using your continuity meter to make sure your using the correct pair of contacts for your use, ie normally open or normally closed.SUPERSPRINT2019-03-26 12:14:19
big10p
6,093CR
Ah! Yes, I'll meter the contacts before wiring it up. Cheers!
(3rd time lucky with posting this reply. I think the server must be feeling Ill again.
big10p2019-03-26 12:30:45
big10p
6,093CR
Just got round to wiring this up over the weekend and noticed the test tab doesn't seem to do anything. I don't get any continuity to the NO terminals with the tab pulled out as far as it'll go. I wired up the relay on the bench to test it and it seems to be working fine. Is the tab not working anything to worry about?
big10p
6,093CR
One last thing (promise!) - Do I need to fuse the relay connection to the monitor? I kind of assumed I don't as the cab mains inlet is already fused.
RaveN
1,325CR
Make sure it's not a fake. The auction model number is for an Omron relay that would normally cost about 5 times the value of that auction.
big10p
6,093CR
I actually bought this one which cost more but I didn't want to wait 2+ weeks for delivery. It seems to work fine, apart from the test tab. I hadn't even thought about fakes, TBH. Is there any way to tell a fake, apart from the cheap price?
It actually says "designed in Japan" and "made in China" on it.
big10p2019-04-12 18:18:27
obcd
3,830CR
The orange spring loaded tab is the release tab for the relay socket. Those sockets can be mounted on a din rail by clicking them on it. To remove them, you have to pull out that orange tab that releases the lock. If you turn the assembly upside down you should see it. I doubt it matters much if it's a fake relais. It's not like it will switch 100 times/day for several years.
Some relays have a small test button to manually activate them, but not all of them. Some also have a small indicator that shows if the relays is activated or not. If your cabinet is fused, there is no need to fuse the relais as well. If something bad happens, your cabinet fuse will do the job.
big10p
6,093CR
Ah, that makes things clearer. Thanks!
