Replace MTC900 for a 900E chassis?
Ronnie Dent
1,206CR
Cheers again Tony, yes the neck socket looks to be the same, whilst testing the 900 and checking stuff I lost a leg from the TDA2593 IC it was so tight in the socket should have left it be!
Cheers Ronnie
Ronnie Dent
1,206CR
Had almost completed the transplant down to fitting the neck card when I noticed this! So that was the end of that idea!
Ronnie Dent
1,206CR
tb2000 said:
That's burnt out because the transistor nearest to it is very likely shorted.
That's what I thought Tony but it does not read short.
I went ahead and fitted this chassis and it's working with a bright red raster? No point in replacing the resistor until I find out what burnt it!
Thanks Ronnie
