Thanks ,This IC has a thermal pad which makes it a little more complicated. If you just heat it up with a heat gun, you will stress the IC more than neccessary. You have to heat the pcb through the IC - and thats not a good idea. If you're lucky, the IC survives. If not, the pcb will become black and delaminated.
So there are a few recommendations I would follow:
It's mandatory the thermal pad is soldered. Not soldering this pad will overheat the IC when it's in use. It's important there's not too much solder paste or solder on that pad when soldering, too, because the IC otherwise will swim on a solder blob and the outer connections will not become soldered correctly.
For reaching this goal, the pcb should be preheated (approx. 150 °C) from below so the heat gun from above has just to lift the temperature by several 10 degrees for soldering.
Using liquid flux is not recommended, because it 'cooks' during soldering and the vapour bubbles are lifting the IC from the pads on the pcb. So using a honey type flux will be a better option.
Good luck!
I could cut a small hole in somethingThanks ,
I don’t have a heat source to put underneath , ?
Unless I use the hot air underneath first
Then finish a few seconds on top . ?
Im removing because the ic is already toast .. so I don’t need to worry about
Damaging it in the removal
Thank you , yes I did think through all the above .. I will use toaster and hopefully it worksNo, the center pad is intended to be soldered. If you put on thermal paste, I don't know what's happening. First, the heat disapation will be not as good as it is if soldered, but of course better than doing nothing. Is it enough? I don't know. If your chip dies, you know why. If it doesn't, you're lucky. Second: How will you make sure absolutely nothing of the thermal paste reaches the pads around the thermal pad (center pad)? If solder and thermal paste are mixed, I'm quite sure this will lead to a bad solder joint. On the other hand, if you use not enough thermal paste to prevent this, how will you know if there is a thermal connection between the thermal pad and the pad on the pcb?
The center pad may be optional to connect electrically, but chips having a thermal pad usually need this for power disapation. Often there are vias inside the pad of the pcb to lead the heat to the bottom side of the pcb (or to an inner layer if it's a multilayer pcb) where a bigger area of copper does the function of a heatsink.
The toaster may be a good option for preheating, too - but you shouldn't use it for food any more after doing this. Solder isn't very healthy, especially the flux and the lead. And you have to be very careful that nothing falls into the toaster.
There are also instructions on the web to build a simple soldering oven from a small, cheap pizza oven by replacing its control unit. Not as good as a real one, but it works. But this is not an option for a single task, of course.
Here's a sample of a professional preheater used for such tasks usually: Weller WHP200 (just for reference).
Yen such a tiny chipWarm the other side for a bit, with the heat gun, then go for it . It's a little chip, the pads are partially exposed, and it's unlikely to have loads of hidden thermal vias, looking at the board.
Obviously know when to give up - don't keep the heat on for minutes, incinerating the board and don't ever try and lever it off as that certainly will knack the board. You'll likely also end up melting the solder on the nearby resistors, so don't wave it around doing this.
