Yeah, you'll need to discharge the crt if you've had it turned on in the last little while, either buy a proper high voltage discharge probe or make your own. You can make a cheap discharge probe using a decent size flat blade screwdriver and a length of wire with a crocodile clip attached. Attach one end of the wire to the earth braid on the rear of the tube, attach the other end to your screwdriver's shaft. If you're worried about safety put your other hand in your pocket, and gently slide the screwdriver under the cap - and don't touch the shaft, just the screwdriver handle (which needs to be plastic or some other non-conductive material), you can insulate the shaft if you like and/or wear a glove. You should hear a snap. Wait a few minutes and do it again. When you hear no snaps, you can remove the anode cap. You can usually lift the edge of the cap with the screwdriver and at the same time push on one of the legs on the clip (under the cap) that holds it to the crt. Once one leg is out, the other should come out easy by pulling the cap to one side. Removing the chassis is easy once the cap is off. Remove the neckboard by gently pulling it towards you away from the crt (very slightly rocking it side to side). Remove the neckboard earth wire. Remove the yoke wire from the chassis (6 pin green plug near the lopt). Remove the degauss wire (2 pin green plug). Remove the 4 pin power plug and the 6 pin rgb signal plug from the front left of the chassis. Take out the two screws and remove the chassis from the frame. Job done.
Edit: Oh and it's probably pretty obvious, but never put a screwdriver type discharge probe under the anode cap when the chassis is on. You can do that with the proper discharge probe as they have a huge bleed resistor inside and connection for a multimeter (they're actually usually used for making sure the HV level is correct).
tb20002020-07-26 19:50:58
