I recently picked up a System 1 cab and was a bit taken back at just how loud the cooling fan was.
The fan fitted was a TA450 (AC115V 0.26A/.21A), so I thought I would try a TA450S (115V 50/60Hz .110/.104A).
I was a bit concerned that the TA450S might not have oopmf to keep the AR3 cool, so I did a little test.... results below:
For each test, I let the AR3 cool to the room ambient temperature of 73 degrees.
Test 1 - No Fan
Decibel reading: 44db
Temp reading of AR3
Time ¦ Temperature degrees F
Start ¦ 73
1 min ¦ 97
I stopped test 1 at this point - the AR3 was getting very hot, very quickly.
Test 2 - Original fan TA450
Decibel reading: 72db
Temp reading of AR3
Start ¦ 73
1 min ¦ 81
2 min ¦ 84
3 min ¦ 88
4 min ¦ 90
5 min ¦ 90
6 min ¦ 90
10 min ¦ 91
15 min ¦ 90
Test 3 - Lower amp fan TA450S
Decibel reading: 63db
Temp reading of AR3
Start ¦ 73
1 min ¦ 81
2 min ¦ 82
3 min ¦ 84
4 min ¦ 86
5 min ¦ 88
6 min ¦ 88
10 min ¦ 88
15 min ¦ 90
First lesson learnt... don't attempt to use an AR3 without a cooling fan!
Second lesson, if you want to reduce the volume, the TA450S appears to perform similarly to the original and louder TA450.
Anyone have any experience of using alternate fans with a AR3 cab? Any concerns about using the TA450S??
Test 1 - No Fan
Temp reading of AR3
Start ¦ 73
1 min ¦ 97
Temp reading of AR3
Start ¦ 73
1 min ¦ 81
2 min ¦ 84
3 min ¦ 88
4 min ¦ 90
5 min ¦ 90
6 min ¦ 90
10 min ¦ 91
15 min ¦ 90
Temp reading of AR3
Start ¦ 73
1 min ¦ 81
2 min ¦ 82
3 min ¦ 84
4 min ¦ 86
5 min ¦ 88
6 min ¦ 88
10 min ¦ 88
15 min ¦ 90
