Replacement for light strips?
system11
9 (100%)
345CR
What's the go-to replacement now for flourescent light strips? I've got the standard 240v feed, starter & ballast etc setup and I need to replace it with something modern.
Outrun2
Colonel Outrun
1,181CR
I've used T5 LED strips on some of my drivers - bypass starter and ballast and just connect direct to supply. My original go-to supplier did versions that catered for 90-265VAC but has been out of stock for a while.
If you have a 240VAC supply you could go for one of these..
https://www.ebay.co.uk/itm/401256303124?hash=item5d6cbd4a14:g:pYAAOSwt5hYcQER
I always choose 'warm white' though as the 'cool white' versions feel too harsh and bright for that old school 80s feel.
system11
9 (100%)
345CR
Too big - I'll have to take it out to measure. Naturally a chimpanzee has worked on the machine and the whole board and lamp assembly is loose. I don't think I've ever had to do so much work on a machine that technically was 100% functional before.
Outrun2
Colonel Outrun
1,181CR
What cab is it?
You can get LED bulbs/tubes that fit into the original fitting - they come with a dummy starter but you'd need to check size.
Either that or LED tape diffused and cut to length?
system11
9 (100%)
345CR
Rad Mobile, it'll be a day before I can get to the front of the machine again and pop the glass out to check size. The glass is shot too of course but muddymusic made a repro!
