Replacement WG6100 Capacitors?
RolyRetro
278CR
I'm attempting a repair on a WG6100 deflection board, and have found one of the big capacitors (C101) is dead, not getting any reading on the multimeter, whereas the other one C100 gives a nice rising reading.
I'd like to replace both and have removed from the deflection board, but I'm not able to find a suitable replacement. The capacitors are 4700uf 50V with 3 legs, but I can only find 2 leg replacements?
Can these be substituted, and if so what do I need to do with the missing 3rd leg?
philmurr
48 (100%)
2,374CR
Schematic and parts list shows them as standard caps and not dual or anything special so an ordinary 2 pin cap will work.
The 3rd pin is commoned on the PCB so just make sure you get the new caps the right way round.
RolyRetro
278CR
Cheers - ordered from RS Components this evening
