Replacing Power Wiring. (NAC)
geldra
21CR
Hello,
I’ve started the process of cleaning/restoring an Alpha1 NAC and have found my first bit of dodgy wiring coming from the wiring just after the kettle lead/noise filter(pic attached), it’s probably wise to replace the whole length, my question is, what gauge of wire should I use?
(Brown and Blue wires in the pic).
Cheers!
geldra2018-04-25 11:29:27
Jon-A-Tron
330CR
So it's probably the 230v supply in then and the red/blue tapped off to supply a marque light or something.
2.5mm should be good. If you can find the manual with a diagram to see what the current requirement is then that would be ideal.
Put a little terminal box there for the extra wires or run them to the transformer if they reach. This is the sort of cut-n-shut splices that, when the tape falls off, your watch catches the cable and you get a zap. Nasty.
geldra
21CR
Thanks guys. Yeah from the looks of it, the spliced in wiring goes to the marquee light (which isn’t the original lighting, it’s an actual screw-in light fitting)
davey d
480CR
Mmmmm quality modification there
If that's all that its running, then smaller wire will be fine. I think it might even be 0.75mm2 for that lighting
geldra
21CR
Oh naaa, the wire that goes up to the light is spliced in from main (thicker) wire.
What I don’t understand is why they’ve done it. Surely there was actual wiring going up to the actual original lighting bracket.
davey d
480CR
geldra said:
.....Surely there was actual wiring going up to the actual original lighting bracket.
Yes the original wiring runs up the inside front of the cabinet. When you open the big service door it should be pinned into the inside left corner going up inside the cabinet
