Resistor check
8,288CR
Can anyone help me out reading the larger grey resistors
Which I believe is green =5 Blue =6 Red =x100. Gold +-5% tolorence
5600. Ohms
I can see the 5k6 5watt resistor on this schematic …
Am I right that this is the resistor
So I’m looking to get a 5600 ohm 5 watt …. Or as close to the whattage. As possible …. Like can I go up or down a couple of whatts ?
With no harm. But for exsample 5600 ohm 1 watt would be to low?
Thanks for the help
Retroman8392022-05-28 08:21:49
cliff_poole
1,069CR
I think you are right with the reading and it will have to be 5W. Those resistors are also fuseable types, they are designed to blow without catching fire if they sink too much current. Problem is, the heat changes the colours of the bands over time which is why they are so difficult to read. You are right to have checked the circuit diagram and go by that.
8,288CR
Thanks cliff, very helpfull
Hey do you think that the person /manufacturer made a mistake or
Just used what was available to them at the time ?for the resistor
That has blown.. as it’s not matching & seems to be original alongside the rest.
But also I guess it’s possible that another owner before me has changed it previously..
I’m going to remove the transistor in circuit
And I known good transistor from the other two colour circuits and compare continuity. B C E.
To see if the transistor in the red circuit is also short. Retroman8392022-05-28 11:18:33
big10p
Coins detected in pocket!
6,084CR
As Cliff says, the heat has probably just discoloured the bands. The colours they look like now make no sense as far as resistor codes go.
8,288CR
Agh ok wow it’s really cooked them colours then
And looks swollen
Another great indicator to look for.
Thank you big 10 very helpfull Retroman8392022-05-28 11:44:42
