If anyone is buying one, I'd recommend the SD card option.
Some of the features I like include...
With the MAME CRC list on the SD card (available from the download site), the RCT will automatically identify ROMS.
It has a built in routine to dump a truth table for PALs and GALs if you specify inputs and outputs (I've not tested this yet).
You can create your own custom device pinouts for tests by adding as a text file to the SD card.
For old RAM chips such as 4116, a supply decoupling capacitor can be jumpered in. The reason for the jumpers is down to the different pinouts for different chips. This is useful because the power is applied to the chip at point the test starts. Some old chips can cause a power spike due to initial higher current requirement, which can cause the test to be unreliable. I have found this on other testers.
It is really well supported. There is a forum, and new devices are being added all the time.
In general use, the tests feel very solid and reliable.
