Retro console upscaler recommendation
channel27
1,259CR
Hi all,
What's the go-to bit of kit for playing retro consoles and computers (that output RGB / Scart) on a HDMI TV, these days?
I've got a cheapo Scart -> HDMI converter from Amazon but I'm looking for something a bit more compatible / reliable / configurable.
Is an OSSC the way to go?
I got some of the bits to convert a GBS8200 with the GBS Control firmware but I'm not sure I can be arsed with my failing eyesight and sausage fingers :LOL:
Cheers,
Rob
CMYKhazi-Dan
Saikyo Style 💪
1,301CR
Hi all,
Cheers,
Rob
Retrotink 5x is the best
I sold mine and have now got some gbsc based orange box thing off Amazon.
I have all the shit to convert a GBSC, but what a software-based Wi-Fi pain the arse!
Stokers
36 (100%)
1,992CR
Hi all,
Cheers,
Rob
I'm surprised there isn't a user called 'Sausage Fingers' on here.
I've used the OSSC quite a bit, it works great. It doesn't have all the features (mostly output resolutions I think) of the retrotink but it provides very clean output.
kingtreelo
18 (100%)
1,496CR
as others have said, the OSSC is the cheapest and best way to if you dont want to spend a fortune
i have had problems with snes and ossc though, and it took a LOT of messing about to get it correct, i think the tink just eliminates all of that messing about, so be prepared for some messing about if you go down the OSSC route, i think i ended up juts buying a few CRTs instead and a MiSTer for my big telly to save the hassle
SquidDude
119CR
The RT4K CE seems like a pretty good deal, especially for arcade stuff. £475 from a UK seller vs the £750 of the Pro model.
The extra features you get on the Pro don't really matter too much for arcade imo (unless you play on a big TV and want to use the rotate feature)
I got the 4K "Pro" before the CE was announced (expensive, but I really needed a few of the extra features on it vs the ossc), but honestly I could totally get away with the CE now
Vamino
Insert coin(s)
22 (100%)
2,621CR
I've got both the OSSC and the RT4K.
I also have a GBS-8200 Control, but it's FW is way out of date and I don't know how much it's improved since I last updated it.
For console gaming, I'd go with the OSSC if you are not playing too much PS2, as it's very good when used with quality video cables. But, it does have issues with some games that switch resolutions, the deinterlacing isn't the best and it's max output is 1080p.
For video archival purposes and for the feature set, the RT4K is the best, but that comes at a cost.
Inbetween the OSSC and RT4K you have OSSC Pro (1440p, good at deinterlacing and good downscaling) and RT4K CE.
All have something to offer, so it may be worth reading up on their strengths and weaknesses.
