Reverse Engineering Atari 'SLAGS' IC's
smarty
Ready Player One
1,305CR
Very impressive, well done Col.
I take it the only source for these SLAGS is from robbing them from boards not the 'NOS' market? Hopefully this will help folk out who the customs gone faulty.
ColinD
6 (86%)
1,367CR
Yes, that's right.... they are hard to find, so now we have a modern equivalent.
I needed a few myself which is why I've gone to the trouble. They will be reasonably priced too.
Cheers, Colin
Mitchell Gant
888CR
That looks like an Altera part on your V2. Which chip is it exactly?
I take it you've done a V1 with a Xilinx part and V2 with an Altera as an alternative. If so will there be some V2 PCBs for sale at some point, I may be interested in a couple.
I've dabbled a bit with some Altera parts and Quartus, but no Xilinx stuff.
ColinD
6 (86%)
1,367CR
Yes... The v1 uses a xilinx 3.3v part (with 5v tolerant i/o) and a regulator, the v2 uses an Altera 5v part , EPM7064STC44-10 , £10 from Farnell.
The v2 also allows you to use different power input pins for other designs and an optional 3.3v regulator for a different xilinx part. Atmel also do a part that will fit (ATF1504AS).
I may do a slimmed down V3 that just does the SLAGS once further tested although V2 is fine too.
ColinD
6 (86%)
1,367CR
Did some more testing yesterday and found that there are still some issues that were not apparent in the game demo mode (ran diagnostics on the gauntlet pcb and tried a few tests out with pallets and flipping the sprites around). There were some vertical stripes again when flipping (left to right mirror imaging) , much like the first teething problem.
I've been through all the vhdl code last night, and think I've found a little bug (needs a 1 replacing with a 0), so will report back once I've tested again... The great thing about these parts is that you can tweak and reprogram them, if this was a hardware design with individual parts it would be quite an effort to respin.
I want this to be spot on before I send a couple of free samples out for people to try.
EDIT - That's fixed it , its flipping wonderful now :) - Basically it was clocking data in when it shouldn't which kind of randomized it, and not clocking data bits in when it should.
One of these was the flip select signal so the shift registers would have got confused somewhat further down the line shifting/clocking/shuffling the graphics bits out in random directions instead of one way or the other.
do_latch: process (nEN, CK)
begin
if CK'event and CK = '1' then
if nEN = '0' then Q <= D; -- changed from 1 to 0
end if; end if;
end process;
ColinD2014-11-17 19:43:27
ColinD
6 (86%)
1,367CR
A little progress to report....
I built a pcb to hold a repro and an original ic and it compares the outputs..... I found a little glitch !!
I've now had this on a logic analyzer and its a factory fitted glitch on the gauntlet pcb which only happens off screen... the gfx eproms change over while its trying to load data, the repro is faster than the original chip and catches the eproms swapping over, but is based on the schematics.
I'm now fairly confident that this won't cause any issues so have ordered a few more cpld's and going to build a small batch.... next will be testing 4 of them on road blasters and then hopefully I will be offering these up for sale in limited quantities... at about £20 to £25 each. I'm also looking at a different device to keep the cost down as the current chip costs around £7 or so, and that's before all the other parts, pcb's and time is taken into account !!
Those of you that follow me on facebook will have a good idea of the extra work I've put in,making sure this works well :)
Cheers, Col
ColinD2015-08-06 19:31:06
ColinD
6 (86%)
1,367CR
virtvic
The Cabaret King
21 (96%)
2,013CR
Colin D...
Keeping stuff alive!
I don't understand any of it apart from the fact that Col and all the people involved are electronic demi gods
ColinD
6 (86%)
1,367CR
Had some more boards made up to test a further design..... (pretty much the same but more versatile for experimenting with)
These look ace !! (and can also be configured as other types of plug in modules due to some power link pads so then very much like the arcadefpga modules) - They snap out of the panel (well gently cut or sawed anyway !!) - EDIT... Looks like they missed out some of the milling on the bottom left... all the other pcb panels I had made are spot on , so trust me to photo the odd one out !!
I'm doing another version with a slight mod (1 jtag restor pulled down instead of high) and will also add some cover slip's to pop on top , giving extra shielding and also acting as a heat sink on device.... With a bit of glue, heatsink compound and black nail varnish it should look very much like a propper chip !! (NOTE to myself, need to make the cover slip fit all the designs, so might need some extra pads to solder the gnd to that fit all !!)
I'm not sure if if want to go for thinner boards now as doing a sandwich jobbie, but with thicker boards, the whole module is more solid and robust.
The cover slip will look like this, but you will still be able to get at the pads for the pins incase you need to replace them.
ColinD2015-11-13 21:17:04
Dex-Jay
375CR
Not only will the work ace but they'll look factory too! Nice work Col!
My Roadblasters will be a happy bunny with 1 or 2 of those fitted! (pew,pew)
