roadblasters graphic issue
JESSYBR
163CR
hi there my roadblasters has an issue
vertical stripes on the screen
rom and ram test oke
game plays oke
tips are welcome
andyJay
98CR
i had a double dragon 2 board that had something similar,faulty ram.
some boards can test ok for the ram but there can still be a fault,have you got a schematic for the board? if not it might be worth poking around shorting the data lines on various ram chips to see if you can locate the section thats causing the prob,also if youve got an ESR meter check the filter caps for any daft out of spec values.
RGP
Meeter & Greeter
2,039CR
This will likely be in the sprite ram for sure. Nthere are 4 x 2148 rams on the cpu biard towards the left edge, at least one of those will be trouble OR the multiplexing or shifting circuit.
I don't have the schemes in front of me.
The reason on all game boards like this why the ram doesn't indicate failure is because its not accessible to the cpu. There will be an area in cpu accessible ram that the game code writes to to enable a sprite - this can be checked by the power on tests but then the graphics hardware will use the values in work ram to build the sprite buffers in thise chips but the cpu can't talk to them directly so can't verify them.
Other games with fraphics co processors can sometimes talk to this bit of mempry and then report test status back to the primary cpu doing start up tests.
JESSYBR
163CR
hi located those ram chips
maybe i am thinking too easy,but pulled out my fluke
and started too compare the resistance of the four rams
if a check all four the same way i get the same readings
but c87 ram is way different,could that be the faulty one??
since the fluke is all i have,or does that tell me nothing??
or other ways of testing(first attempt too fix a board)
gr robert
edit 5 volt is coming too pin 18 on all 4
JESSYBR2015-07-10 17:22:42
RGP
Meeter & Greeter
2,039CR
I usually use a scope and look at the data signals coming out of them.
ColinD showed me how to use channel B on my scope to be a trigger sensor for the select pin on the chip so I could see only the data involved on that chip.
You'll see a stuck low or stuck hi pin.
Use the game's test mode and get to motion object height test to see the ram chips used in a predictable repetitive way.
Or just desolder all four, fit sockets and the swap them around or replace them one at a time to see if a change happens.
