Robotron Joystick Replacements
4,058CR
I posted this on the FB page while the site was down, but now we're back I'll put it here...
First up, what is the exact length of the original shafts on a Roby? From CP to the bottom of the ball?
Next...
I needed to get some sticks for my Roby. New Wico's are proving nigh on impossible to locate and I wanted some sticks by today so I can go and get the control panel finished off this evening (the guy's had it since before Xmas).
I ordered in one of the Ultimarc 360 joysticks to see what they were like since they don't use any kind of switch so I figure they'll feel the most like leaf switches. They're seriously expensive mind so only got 1 to try at the moment and I figure I can always sell it on later if they're no good for what I want them for.
SO, arrived earlier and my opinion is that they'll likely be what I go with, but only after spending even more money - which is kinda dissapointing! As standard they're too sloppy and have too much travel. Luckily I saw this coming and ordered stiffer springs at the same time. With the stiffer spring fitted they feel a bit 'grindy'. Hmm. And obviously they still have too much travel (IMO) as nothings changed there. I seriously don't think the quality here matches the price tag, but I guess that's what you get when you can only buy them from one place.
So, it seems that you can get restrictor plates for them. Yet more money, but it should solve both problems so I guess it's the final piece of the jigsaw.
Anyone have any thoughts of which restrictor plate would give the closest feel to the original Wico sticks? I don't have a Wico to compare to so need someone elses judgment on this one.
The choices I have are:
  • Round - just restricts the movement a bit but doesn't add any corners or edges.
  • 4-8 way - is basically a square with rounded corners
  • Octagonal - err, speaks for itself?
So what should I try? If I can get this right first time then I'd like to as the cost of this panel is REALLY ramping up, especially given I'd like to get some longer shafts made up to the same size as the original sticks too.
tb lilley
5 Star
1,686CR
There's a guy over on KLOV that is selling repro sticks (just the sticks themselves)
http://forums.arcade-museum.com/showthread.php?t=226191
I almost bought a pair as mine were very rusty. But stuck them in a drill instead and applied sandpaper, came up really nice:
I have a single Wico left, but is missing leaf switches, a spring, and the white plastic piece that sits on the end. Probably not much use to you ....
5,653CR
Hey,
I think Gudds Robotron has a repro cardboard bezel. Be lovely to show him the TOG glass stuff for the Euro Robotrons. I'm sure he'd get them too
4,058CR
If the shafts on yours are the full size 4" ones then could you measure from the surface of the CP to the bottom of the ball please? The problem with buying any in is that they will need to fit the Ultimarc sticks, assuming that's what I end up going with. And that's the same reason that knowing they're 4" long doesn't help me either. For Wicos 1" of that could be underneath the stick, for mine, 2.5" of it (etc). So the only way to get it right is to getting made.
Also, the guy on Klov has made the sticks out of stainless and that's, for the most part non-magnetic. The Ultimarc sticks are kind of hall effect sticks. But regardless of what they are exactly, they have a neodymium magnet that sticks to the end of the shaft, which obviously wouldn't work with a stainless shaft.
4,058CR
Nice!! I've not done much with the bezel yet. I've got the glass made up but haven't tried to put the artwork behind it yet...
4,058CR
All I've got for a marquee is ne printed on cardboard! It does the job ut it does look pretty naff with a light behind it.
tb lilley
5 Star
1,686CR
No worries.
TOG = www.thisoldgame.com
You won't find any of the Roby stuff on the website - but you might notice that he does custom jobs. As he now has the artwork it probably wouldn't take him too long to turn around another commission. Feel free to mention my name - it's a recent job and still probably fresh in his mind.
Word of caution though, if you order, be really really careful about measurements for bezel. He prints these to tempered glass which can't be shaved / cut. Mine is mill perfect, but another couple of mill either side and it wouldn't have gone in. If I were doing it again I'd probably allow a bit of slack.
tb lilley
5 Star
1,686CR
guddler said:
Dare I ask how much it all set you back including shipping? Looks very nice though
In paid for them months ago .... took some sorting .... but I'm pretty sure cost was about $200, maybe as high as $250 (I'm trying to forget ..) - price included shipping. Steep, but oh so fine ...
tb lilley
5 Star
1,686CR
The visible shaft, from bottom to where it enters the ball top (yes, I know, fnarr etc) is 3.5". I'm sure I had sticks that were shorter than this in the past, but could be wrong. The sticks 'feel' right, but yeah, I think you can get them .5" longer.
Edit: that said, my sticks sit in a piece of wood bolted to the control panel. That wood has been routed out to allow the housing to drop in. If not, the sticks would have to be fitted on the flat underside of the wood, and 3.5" would look very short .... I'll say it again though, the sticks really do feel and look right as they are. Mind you, I've got nothing to compare them to other than a very hazy set of memories .... Maybe another .5" might improve them ....tb lilley2012-05-03 21:03:28
