Rom Burner Recommendation
jerryspaghetti
38 (100%)
2,004CR
Looking for some recommendations for a chip burner.
I'm hoping there's one that can burn Konami, capcom CPS & Nintendo type rom chips although I understand the Nintendo ones might need a higher end burner than my budget might allow.
Looking to spend about £100 tops and seen the TL866 is a bit of a budget 'go to' burner.
Any advice most welcome, cheers!
TheDaddy
14 (93%)
7,230CR
TL866 with the 27C160 converter (CPS1). I use it on 99% of my stuff. The older stuff is a bitch to burn as they need additional power. Not got around to playing with that yet.
Dave.
jerryspaghetti
38 (100%)
2,004CR
Dave.
Cheers Dave, will that burn Konami eproms? Want to be able to burn 2p and 4p sets for 4 player PCBs.
I did read somewhere that the Nintendo stuff needed a 25v burner
Cheers.
TheDaddy
14 (93%)
7,230CR
What type are the konami ones? is it the 2732 / 16 ones (Cant remember exactly) If its them I replaced them with 27C32's / 16s to get round voltage issue. I would need to check as ages ago and I get confused !
Dave.
bones
1,628CR
Dave.
yeah I've got one and I've managed to burn the 25v vpp ones by bending the vpp leg out of the Ziff socket and putting a small single terminal block on it. Then I've got an old plug top 24vdc power lead that I've chopped the DC plug off of and connect the positive into the terminal block and pop the negative in with the ground pin in the Ziff socket. I try to work it so it's only powered on briefly before before I hit program just in case lol. But it does mean I can recycle a lot of my defunct 2716 roms successfully. It's just the 2708s I can't do really but there's normally other ways to get round that.
